ArcGIS.Core.CIM Namespace / CIMKGTraversalDirection Class
Members Example
    Represents a Knowledge Graph Filtered Find Paths TraversalDirection. The filtered find paths algorithm uses traversal directions to specify how relationships are traversed. When no traversal direction is defined for a specific relationship type, the default traversal direction is used.
    Object Model
    CIMKGTraversalDirection ClassCIMKGTraversalDirection ClassCIMKGTraversalDirection Class
    Syntax
    Example
    Run FFP Using Traversal Filters
      //using ArcGIS.Core.Data.Knowledge.Extensions;
      await QueuedTask.Run(() =>
        var ffp_config = new CIMFilteredFindPathsConfiguration();
        ffp_config.Name = "Run FFP w Traversal Filters";
        //set origin entities
        //set destination entities
        //set any path filters
        //Set traversal filters
        //A traversal filter is used to specify the traversal direction of a relationship (to be)
        //included in the result paths. By default, paths are evaluated without considering the
        //direction of relationships in the graph - i.e. KGTraversalDirectionType.Any.
        //Relationships can be evaluated in specific directions by changing the KGTraversalDirectionType
        //enum value of the traversal_filter.TraversalDirectionType.
        //For example, the traversal direction is being set for the following relationship types...
        var traversalFilters = new List<CIMKGTraversalDirection>();
        foreach (var relation in new List<string> { "near_poi", "near_facility", "near_facility2" })
          var traversal_filter = new CIMKGTraversalDirection();
          traversal_filter.RelationshipTypeName = relation;
          //All relationships of the specified type are considered (default)
          traversal_filter.TraversalDirectionType = KGTraversalDirectionType.Any;
          //Relationship can only be traversed from origin to destination
          traversal_filter.TraversalDirectionType = KGTraversalDirectionType.Forward;
          //Relationship can only be traversed from destination to origin
          traversal_filter.TraversalDirectionType = KGTraversalDirectionType.Backward;
          traversalFilters.Add(traversal_filter);
        ffp_config.TraversalDirections = traversalFilters.ToArray();
        //etc.
        //TODO - use the config
        //var results = kg.RunFilteredFindPaths(ffp_config);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMKGTraversalDirection
    Requirements
    ArcGIS Pro version: 3.3 or higher.
