Public Class CIMFilteredFindPathsPathFilter Inherits CIMObject Implements System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
public class CIMFilteredFindPathsPathFilter : CIMObject, System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
//using ArcGIS.Core.Data.Knowledge.Extensions;
await QueuedTask.Run(() =>
var ffp_config = new CIMFilteredFindPathsConfiguration();
ffp_config.Name = "Run FFP w Path Filters";
//set origin entities
//set destination entities
//set path filters
var pathFilters = new List<CIMFilteredFindPathsPathFilter>();
var path_filter = new CIMFilteredFindPathsPathFilter();
path_filter.ItemTypeName = "POI";
path_filter.ItemType = KGPathFilterItemType.Entity;
//To select specific entities, set the ID property or provide a filter predicate
//path_filter.ID = "{B1C2D3E4-F5A6-7B8C-9D0E-1F2A3B4C5D6E}";//set a specific id
//...or...use a predicate
//path_filter.PropertyFilterPredicate = "n.name = 'Robert Johnston'";
//Use IncludeOnly to only consider entities of this type in the path
path_filter.FilterType = KGPathFilterType.IncludeOnly;
//Use Exclude to ignore paths that contain excluded types
path_filter.FilterType = KGPathFilterType.Exclude;
//Use MandatoryWaypoint if you have specific entities/entity types through
//which all paths must pass through at least one entity of this type
path_filter.FilterType = KGPathFilterType.MandatoryWaypoint;
//Use OptionalWaypoint if you have specific entities/entity types through
//which all paths must pass through at least one entity from any of the
//optional waypoints
path_filter.FilterType = KGPathFilterType.OptionalWaypoint;
//Add the path filter(s) to the collection
pathFilters.Add(path_filter);
//Add more filters as needed
//"Person", "Supplier", "Plant", etc.
//Path Filters
ffp_config.PathFilters = pathFilters.ToArray();
//TODO - use the config
//var results = kg.RunFilteredFindPaths(ffp_config);
System.Object
ArcGIS.Core.CIM.CIMObject
ArcGIS.Core.CIM.CIMFilteredFindPathsPathFilter
