ArcGIS.Core.CIM Namespace / CIMStroke Class
Members Example
    CIMStroke Class
    Represents a stroke which defines how line geometry or the outline of polygon geometry is drawn.
    Syntax
    Example
    Create Ellipse Graphic Element
      //Note: Must be on QueuedTask.Run
      //Build geometry
      Coordinate2D center = new Coordinate2D(2, 2.75);
      var eabElp = new EllipticArcBuilderEx(center, 0, 1, 0.45,
                                          ArcOrientation.ArcClockwise);
      var ellipse = eabElp.ToSegment();
      //Set symbology, create and add element to layout
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
                                      ColorFactory.Instance.GreenRGB, 2.0,
                              SimpleLineStyle.Dot);
      CIMPolygonSymbol ellipseSym = SymbolFactory.Instance.ConstructPolygonSymbol(
                                ColorFactory.Instance.GreyRGB, SimpleFillStyle.Vertical,
                                                        outline);
      var poly = PolygonBuilderEx.CreatePolygon(
        PolylineBuilderEx.CreatePolyline(ellipse, AttributeFlags.AllAttributes));
      var elpElm = ElementFactory.Instance.CreateGraphicElement(
        layout, poly, ellipseSym, "New Ellipse");
    Create Lasso Polygon, Freehand Element
      List<Coordinate2D> plyCoords = new List<Coordinate2D>();
      plyCoords.Add(new Coordinate2D(1, 1));
      plyCoords.Add(new Coordinate2D(1.25, 2));
      plyCoords.Add(new Coordinate2D(1.5, 1.1));
      plyCoords.Add(new Coordinate2D(1.75, 2));
      plyCoords.Add(new Coordinate2D(2, 1.1));
      plyCoords.Add(new Coordinate2D(2.25, 2));
      plyCoords.Add(new Coordinate2D(2.5, 1.1));
      plyCoords.Add(new Coordinate2D(2.75, 2));
      plyCoords.Add(new Coordinate2D(3, 1));
      Polygon poly = PolygonBuilderEx.CreatePolygon(plyCoords);
                  ColorFactory.Instance.BlackRGB, 2.0, SimpleLineStyle.Solid);
      CIMPolygonSymbol polySym = SymbolFactory.Instance.ConstructPolygonSymbol(
               ColorFactory.Instance.RedRGB, SimpleFillStyle.ForwardDiagonal, outline);
        layout, poly, polySym, "New Lasso");
    Create Polygon Element
      //Build geometry
      plyCoords.Add(new Coordinate2D(1, 7));
      plyCoords.Add(new Coordinate2D(2, 7));
      plyCoords.Add(new Coordinate2D(2, 6.7));
      plyCoords.Add(new Coordinate2D(3, 6.7));
      plyCoords.Add(new Coordinate2D(3, 6.1));
      plyCoords.Add(new Coordinate2D(1, 6.1));
        ColorFactory.Instance.BlueRGB, 2.0, SimpleLineStyle.DashDotDot);
        layout, poly, polySym, "New Polygon", false);
    Create rectangle graphic with simple symbology
      //Create a simple 2D rectangle graphic and apply simple fill and
      //outline symbols.
      //Build 2D envelope geometry
      Coordinate2D rec_ll = new Coordinate2D(1.0, 4.75);
      Coordinate2D rec_ur = new Coordinate2D(3.0, 5.75);
      Envelope rec_env = EnvelopeBuilderEx.CreateEnvelope(rec_ll, rec_ur);
        ColorFactory.Instance.BlackRGB, 5.0, SimpleLineStyle.Solid);
        ColorFactory.Instance.GreenRGB, SimpleFillStyle.DiagonalCross, outline);
      GraphicElement recElm = ElementFactory.Instance.CreateGraphicElement(
        layout, rec_env, polySym, "New Rectangle");
      //Or use Predefined shape
      GraphicElement recElm2 = ElementFactory.Instance.CreatePredefinedShapeGraphicElement(
                                layout, PredefinedShape.Rectangle, rec_env, polySym,
                                "New Rectangle2");
    How to construct a polygon symbol of specific color, fill style and outline
        CIMStroke outline = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.BlueRGB, 2.0, SimpleLineStyle.Solid);
        CIMPolygonSymbol fillWithOutline = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.RedRGB, SimpleFillStyle.Solid, outline);
    How to construct a line symbol from a stroke
        CIMStroke stroke = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.BlackRGB, 2.0);
        CIMLineSymbol lineSymbolFromStroke = SymbolFactory.Instance.ConstructLineSymbol(stroke);
    Gradient color fill using CIMGradientFill
    /// <summary>
    /// Create a polygon symbol with a gradient color fill. <br/>
    /// ![PolygonSymbolGradientColor](https://ArcGIS.github.io/arcgis-pro-sdk/images/Symbology/polygon-gradient-color.png)
    /// 1. Create a solid colored stroke with 50% transparency
    /// 1. Create a fill using gradient colors red through green
    /// 1. Apply both the stroke and fill as a symbol layer array to the new PolygonSymbol
    /// </summary>
      //Note: Run withing QueuedTask
      var trans = 50.0;//semi transparent
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(CIMColor.CreateRGBColor(0, 0, 0, trans), 2.0, SimpleLineStyle.Solid);
      //Mimic cross hatch
      CIMFill solidColorHatch =
             new CIMGradientFill()
               ColorRamp = ColorFactory.Instance.ConstructColorRamp(ColorRampAlgorithm.LinearContinuous,
                                    ColorFactory.Instance.RedRGB, ColorFactory.Instance.GreenRGB)
      List<CIMSymbolLayer> symbolLayers = new List<CIMSymbolLayer>
                  outline,
                  solidColorHatch
      CIMPolygonSymbol gradientColorFillPolygon = new CIMPolygonSymbol() { SymbolLayers = symbolLayers.ToArray() };
      //To apply the symbol to a polygon feature layer
      //var renderer = theLayer.GetRenderer() as CIMSimpleRenderer;
      //renderer.Symbol = gradientColorFillPolygon.MakeSymbolReference();
      //theLayer.SetRenderer(renderer);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMSymbolLayer
             ArcGIS.Core.CIM.CIMStroke
                ArcGIS.Core.CIM.CIMGradientStroke
                ArcGIS.Core.CIM.CIMPictureStroke
                ArcGIS.Core.CIM.CIMSolidStroke
    Requirements
