Public Class CIMSolidStroke Inherits CIMStroke Implements System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
public class CIMSolidStroke : CIMStroke, System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
/// <summary> /// Create a line symbol with a dash and two markers.<br/> /// This line symbol comprises three symbol layers listed below: /// 1. A solid stroke that has dashes. /// 1. A circle marker. /// 1. A square marker. ///  /// </summary> { //Create a line symbol with a dash and two markers. //Note: Run withing QueuedTask CIMLineSymbol dash2MarkersLine = new CIMLineSymbol(); var mySymbolLyrs = new CIMSymbolLayer[] { new CIMSolidStroke() { Color = ColorFactory.Instance.BlackRGB, Enable = true, ColorLocked = true, CapStyle = LineCapStyle.Round, JoinStyle = LineJoinStyle.Round, LineStyle3D = Simple3DLineStyle.Strip, MiterLimit = 10, Width = 1, CloseCaps3D = false, Effects = new CIMGeometricEffect[] { new CIMGeometricEffectDashes() { CustomEndingOffset = 0, DashTemplate = new double[] {20, 10, 20, 10}, LineDashEnding = LineDashEnding.HalfPattern, OffsetAlongLine = 0, ControlPointEnding = LineDashEnding.NoConstraint }, new CIMGeometricEffectOffset() { Method = GeometricEffectOffsetMethod.Bevelled, Offset = 0, Option = GeometricEffectOffsetOption.Fast } }, }, CreateCircleMarkerPerSpecs(), CreateSquareMarkerPerSpecs() }; dash2MarkersLine.SymbolLayers = mySymbolLyrs; static CIMMarker CreateCircleMarkerPerSpecs() { var circleMarker = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.BlackRGB, 5, SimpleMarkerStyle.Circle) as CIMVectorMarker; //Modifying the marker to align with line //First define "markerplacement" CIMMarkerPlacementAlongLineSameSize markerPlacement = new CIMMarkerPlacementAlongLineSameSize() { AngleToLine = true, Offset = 0, Endings = PlacementEndings.Custom, OffsetAlongLine = 15, PlacementTemplate = new double[] { 60 } }; //assign the markerplacement to the marker circleMarker.MarkerPlacement = markerPlacement; return circleMarker; } static CIMMarker CreateSquareMarkerPerSpecs() { var squareMarker = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.BlueRGB, 5, SimpleMarkerStyle.Square) as CIMVectorMarker; CIMMarkerPlacementAlongLineSameSize markerPlacement2 = new CIMMarkerPlacementAlongLineSameSize() { AngleToLine = true, Endings = PlacementEndings.Custom, OffsetAlongLine = 45, PlacementTemplate = new double[] { 60 }, }; squareMarker.MarkerPlacement = markerPlacement2; return squareMarker; } }
/// <summary> /// Create a line symbol with a dash and two markers. <br/> /// In this pattern of creating this symbol, a [CIMVectorMarker](https://pro.arcgis.com/en/pro-app/sdk/api-reference/#topic6176.html) object is created as a new [CIMSymbolLayer](https://pro.arcgis.com/en/pro-app/sdk/api-reference/#topic5503.html). /// The circle and square markers created by [ContructMarker](https://pro.arcgis.com/en/pro-app/sdk/api-reference/#topic12350.html) method is then assigned to the [MarkerGraphics](https://pro.arcgis.com/en/pro-app/sdk/api-reference/#topic6188.html) property of the CIMVectorMarker. /// When using this method, the CIMVectorMarker's [Frame](https://pro.arcgis.com/en/pro-app/sdk/api-reference/#topic6187.html) property needs to be set to the [CIMMarker](https://pro.arcgis.com/en/pro-app/sdk/api-reference/#topic3264.html) object's Frame. /// Similarly, the CIMVectorMarker's [Size](https://pro.arcgis.com/en/pro-app/sdk/api-reference/#topic3284.html) property needs to be set to the CIMMarker object's size. /// This line symbol comprises three symbol layers listed below: /// 1. A solid stroke that has dashes. /// 1. A circle marker. /// 1. A square marker. ///  /// </summary> { // Create a line symbol with a dash and two markers. //default line symbol that will get modified. //Note: Run withing QueuedTask CIMLineSymbol dash2MarkersLine = new CIMLineSymbol(); //circle marker to be used in our line symbol as a layer var circleMarker = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.BlackRGB, 5, SimpleMarkerStyle.Circle) as CIMVectorMarker; //circle marker to be used in our line symbol as a layer var squareMarker = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.BlueRGB, 5, SimpleMarkerStyle.Square) as CIMVectorMarker; //Create the array of layers that make the new line symbol CIMSymbolLayer[] mySymbolLyrs = { new CIMSolidStroke() //dash line { Color = ColorFactory.Instance.BlackRGB, Enable = true, ColorLocked = true, CapStyle = LineCapStyle.Round, JoinStyle = LineJoinStyle.Round, LineStyle3D = Simple3DLineStyle.Strip, MiterLimit = 10, Width = 1, CloseCaps3D = false, Effects = new CIMGeometricEffect[] { new CIMGeometricEffectDashes() { CustomEndingOffset = 0, DashTemplate = new double[] {20, 10, 20, 10}, LineDashEnding = LineDashEnding.HalfPattern, OffsetAlongLine = 0, ControlPointEnding = LineDashEnding.NoConstraint }, new CIMGeometricEffectOffset() { Method = GeometricEffectOffsetMethod.Bevelled, Offset = 0, Option = GeometricEffectOffsetOption.Fast } } }, new CIMVectorMarker() //circle marker { MarkerGraphics = circleMarker.MarkerGraphics, Frame = circleMarker.Frame, //need to match the CIMVector marker's frame to the circleMarker's frame. Size = circleMarker.Size, //need to match the CIMVector marker's size to the circleMarker's size. MarkerPlacement = new CIMMarkerPlacementAlongLineSameSize() { AngleToLine = true, Offset = 0, Endings = PlacementEndings.Custom, OffsetAlongLine = 15, PlacementTemplate = new double[] {60}, } }, new CIMVectorMarker() //square marker { MarkerGraphics = squareMarker.MarkerGraphics, Frame = squareMarker.Frame, //need to match the CIMVector marker's frame to the squareMarker frame. Size = squareMarker.Size, //need to match the CIMVector marker's size to the squareMarker size. MarkerPlacement = new CIMMarkerPlacementAlongLineSameSize() { AngleToLine = true, Endings = PlacementEndings.Custom, OffsetAlongLine = 45, PlacementTemplate = new double[] {60}, } } }; dash2MarkersLine.SymbolLayers = mySymbolLyrs; }
System.Object
ArcGIS.Core.CIM.CIMObject
ArcGIS.Core.CIM.CIMSymbolLayer
ArcGIS.Core.CIM.CIMStroke
ArcGIS.Core.CIM.CIMSolidStroke
