ArcGIS.Core.CIM Namespace / CIMSimpleRenderer Class
Members Example
    Represents a simple renderer.
    Object Model
    CIMSimpleRenderer ClassCIMSimpleRenderer ClassCIMLegendPatch ClassCIMSimpleRenderer ClassCIMSymbolReference Class
    Syntax
    Example
    How to set symbol for a feature layer symbolized with simple renderer
        //Note: Needs QueuedTask to run
        //Get simple renderer from the feature layer
        CIMSimpleRenderer currentRenderer = featureLayer.GetRenderer() as CIMSimpleRenderer;
        if (currentRenderer == null)
            return;
        //Set symbol's real world setting to be the same as that of the feature layer
        symbol.SetRealWorldUnits(featureLayer.UsesRealWorldSymbolSizes);
        //Update the symbol of the current simple renderer
        currentRenderer.Symbol = symbol.MakeSymbolReference();
        //Update the feature layer renderer
        featureLayer.SetRenderer(currentRenderer);
    How to apply a symbol from style to a feature layer
            return;
        //Get symbol from the SymbolStyleItem
        CIMSymbol symbolToApply = symbolStyleItem.Symbol;
        symbolToApply.SetRealWorldUnits(featureLayer.UsesRealWorldSymbolSizes);
        currentRenderer.Symbol = symbolToApply.MakeSymbolReference();
    Simple Renderer for a Polygon feature layer.
    /// <summary>
    /// Renders a Polygon feature layer using a single symbol.
    /// ![Simple Renderer for Polygon features](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/simple-polygon.png)
    /// </summary>
      //Check feature layer name
      //Code works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data
      var featureLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.Name == "USDemographics");
      if (featureLayer == null)
        MessageBox.Show("This renderer works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data", "Data missing");
      //Creating a polygon with a red fill and blue outline.
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
            ColorFactory.Instance.BlueRGB, 2.0, SimpleLineStyle.Solid);
      CIMPolygonSymbol fillWithOutline = SymbolFactory.Instance.ConstructPolygonSymbol(
            ColorFactory.Instance.CreateRGBColor(255, 190, 190), SimpleFillStyle.Solid, outline);
      //Get the layer's current renderer
      //Note: Run within QueuedTask
      CIMSimpleRenderer renderer = featureLayer.GetRenderer() as CIMSimpleRenderer;
      renderer.Symbol = fillWithOutline.MakeSymbolReference();
      featureLayer.SetRenderer(renderer);
    Simple Renderer for a Point feature layer.
    /// <summary>
    /// Renders a Point feature layer using a single symbol.
    /// ![Simple Renderer for Point features](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/simple-point.png)
    /// </summary>
      var featureLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.ShapeType == esriGeometryType.esriGeometryPoint);
        MessageBox.Show("This renderer works with a point feature layer", "Data missing");
      //Create a circle marker
      var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB, 8, SimpleMarkerStyle.Circle);
      renderer.Symbol = pointSymbol.MakeSymbolReference();
    Simple Renderer for a Line feature layer.
    /// <summary>
    /// Renders a Line feature layer using a single symbol.
    /// ![Simple Renderer for Line features](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/simple-line.png)
    /// </summary>
      var featureLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.Name == "U.S. National Transportation Atlas Interstate Highways");
        MessageBox.Show("This renderer works with the U.S. National Transportation Atlas Interstate Highways feature layer available with the ArcGIS Pro SDK Sample data", "Data missing");
      var lineSymbol = SymbolFactory.Instance.ConstructLineSymbol(ColorFactory.Instance.RedRGB, 2, SimpleLineStyle.DashDotDot);
      renderer.Symbol = lineSymbol.MakeSymbolReference();
    Simple Renderer for a Line feature layer using a style from a StyleProjectItem.
    /// <summary>
    /// Renders a Line feature layer using a style from a StyleProjectItem.
    /// ![Simple Renderer Style item](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/simple-line-style-item.png)
    /// </summary>
      //Get all styles in the project
      var styleProjectItem2D = Project.Current.GetItems<StyleProjectItem>().FirstOrDefault(s => s.Name == "ArcGIS 2D");
      //Get a specific style in the project by name
      var arrowLineSymbol = styleProjectItem2D.SearchSymbols(StyleItemType.LineSymbol, "Arrow Line 2 (Mid)")[0];
      if (arrowLineSymbol == null) return;
      var renderer = featureLayer?.GetRenderer() as CIMSimpleRenderer;
      renderer.Symbol = arrowLineSymbol.Symbol.MakeSymbolReference();
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMRenderer
             ArcGIS.Core.CIM.CIMSimpleRenderer
    Requirements
