ArcGIS.Core.CIM Namespace / ExpressionReturnType Enumeration
    Return types for Arcade expressions.
    Syntax
    Members
    MemberDescription
    Date The return type of the expression is treated as a date value by all consumers.
    DateOnly The return type of the expression is treated as a date-only value by all consumers.
    Default The return type of the expression is determined by the consumer using the expression.
    Numeric The return type of the expression is treated as a numeric value by all consumers.
    String The return type of the expression is treated as a string by all consumers.
    Time The return type of the expression is treated as a time value by all consumers.
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.CIM.ExpressionReturnType
    Requirements
