Get and set the link chart layout
//var map = MapView.Active.Map;
// a MapView can encapsulate a link chart IF it's map
// is of type MapType.LinkChart
var isLinkChart = map.MapType == MapType.LinkChart;
// or use the following
// var isLinkChart = map.IsLinkChart;
var mv = MapView.Active;
await QueuedTask.Run(() =>
if (isLinkChart)
// get the layout algorithm
var layoutAlgorithm = mv.GetLinkChartLayout();
// toggle the value
if (layoutAlgorithm == KnowledgeLinkChartLayoutAlgorithm.Geographic_Organic_Standard)
layoutAlgorithm = KnowledgeLinkChartLayoutAlgorithm.Organic_Standard;
else
layoutAlgorithm = KnowledgeLinkChartLayoutAlgorithm.Geographic_Organic_Standard;
// set it
mv.SetLinkChartLayoutAsync(layoutAlgorithm);
// OR set it and force a redraw / update
// await mv.SetLinkChartLayoutAsync(layoutAlgorithm, true);
