ArcGIS.Core.CIM Namespace / CIMKGPaths Class
Members
    CIMKGPaths Class
    Represents the paths found by the Filtered Find Paths search. We use a memory-optimized representation to avoid storing redundant information because it is often the case that a path shares some entities and relationships with many other paths, especially if the Filtered Find Paths configuration uses 'KGPathMode.All'. Definition: a relationship group contains Knowledge Graph relationships associated to a single edge in the local graph. Paths are encoded this way: The path 'p' uses relationships groups PathsBuffer[PathsEndIndex[p-1] .. PathsEndIndex[p]], and: - the origin of the first relationship group is the origin of the path - the destination of the last relationship group is the destination of the path A path of length zero (with entity 'e') has a single relationship group containing no relationship and where the origin and the destination are 'e'. The relationships group 'g' has origin EntitiesUIDs[RelationshipsGroupsFrom[g]], destination EntitiesUIDs[RelationshipsGroupsTo[g]]. Its relationships are RelationshipsGroupsUIDsBuffer[RelationshipsGroupsUIDsEndIndex[g-1] .. RelationshipsGroupsUIDsEndIndex[g]]. The relationship RelationshipsGroupsUIDsBuffer[i] has a cost RelationshipsCosts[i]. if RelationshipsFrom[i] >= 0, relationship RelationshipsGroupsUIDsBuffer[i] has origin EntitiesUIDs[RelationshipsFrom[i]] else the relationship has been deleted after pathfinding. if RelationshipsTo[i] >= 0, relationship RelationshipsGroupsUIDsBuffer[i] has destination EntitiesUIDs[RelationshipsTo[i]] else the relationship has been deleted after pathfinding. Note that origin and destination of a relationship may not match origin and destination of the relationship group because the relationship can be traversed backwards.
    Object Model
    CIMKGPaths ClassCIMKGPaths ClassCIMKGPaths Class
    Syntax
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMKGPaths
    Requirements
    ArcGIS Pro version: 3.5 or higher.
