public class CIMPointGraphic : CIMShapeGraphic, System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
Public Class CIMPointGraphic Inherits CIMShapeGraphic Implements System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
await QueuedTask.Run(() =>
//Place symbol on the layout
MapPoint location = MapPointBuilderEx.CreateMapPoint(new Coordinate2D(9, 1));
//specify a symbol
var pt_symbol = SymbolFactory.Instance.ConstructPointSymbol(
ColorFactory.Instance.GreenRGB);
//create a CIMGraphic
var graphic = new CIMPointGraphic()
Symbol = pt_symbol.MakeSymbolReference(),
Location = location //center of map
//Or use GraphicFactory
var graphicFactory = GraphicFactory.Instance.CreateSimpleGraphic(location, pt_symbol);
ElementFactory.Instance.CreateGraphicElement(layout, graphic);
ElementFactory.Instance.CreateGraphicElement(layout, graphicFactory);
//List of Point graphics
var listGraphics = new List<CIMPointGraphic>();
var listGraphicsFactory = new List<CIMPointGraphic>();
//Symbol
var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(
ColorFactory.Instance.BlackRGB);
//Define size of the array
int dx = 5;
int dy = 5;
MapPoint point = null;
//Create the List of graphics for the array
for (int row = 0; row <= dx; ++row)
for (int col = 0; col <= dy; ++col)
point = MapPointBuilderEx.CreateMapPoint(col, row);
Symbol = pointSymbol.MakeSymbolReference(),
Location = point
listGraphics.Add(graphic);
point, pointSymbol) as CIMPointGraphic;
listGraphicsFactory.Add(graphicFactory);
//Draw the array of graphics
var bulkgraphics = ElementFactory.Instance.CreateGraphicElements(
layout, listGraphics);
var bulkgraphicsFactory = ElementFactory.Instance.CreateGraphicElements(
layout, listGraphicsFactory);
MapPoint point = MapPointBuilderEx.CreateMapPoint(new Coordinate2D(9, 1));
//specify a symbol
var graphic = new CIMGraphicElement()
Graphic = new CIMPointGraphic()
Location = point //A point in the layout
ElementFactory.Instance.CreateElement(layout, graphic);
//Place symbol in the center of the map
var extent = mapView.Extent;
var location = extent.Center;
//specify a symbol
graphicsLayer.AddElement(graphic);
//Point Feature layer to convert into graphics
var lyr = mapView?.Map?.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(s => s.ShapeType == esriGeometryType.esriGeometryPoint);
if (lyr == null)
return;
//Point symbol for graphics
var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(CIMColor.CreateRGBColor(100, 255, 40), 10, SimpleMarkerStyle.Circle);
//Collection to hold the point graphics
var listGraphicElements = new List<CIMGraphic>();
//Iterate through each point feature in the feature layer
using (RowCursor rows = lyr.Search()) //execute
int i = 0;
while (rows.MoveNext())
using var feature = rows.Current as Feature;
//Create a point graphic for the feature
var crimePt = feature.GetShape() as MapPoint;
if (crimePt != null)
var cimGraphicElement = new CIMPointGraphic
Location = crimePt, //MapPoint
//Add the point feature to the collection
listGraphicElements.Add(cimGraphicElement);
i++;
//Magic happens...Add all the features to the Graphics layer
graphicsLayer.AddElements(listGraphicElements);
System.Object
ArcGIS.Core.CIM.CIMObject
ArcGIS.Core.CIM.CIMGraphic
ArcGIS.Core.CIM.CIMShapeGraphic
ArcGIS.Core.CIM.CIMPointGraphic
