ArcGIS.Core.CIM Namespace / CIMGraphicElement Class
Members Example
    Represents the CIM representation of an element on a page layout.
    Object Model
    CIMGraphicElement ClassCIMGraphicElement ClassCIMGraphicElement ClassCIMGraphic ClassMapPoint Class
    Syntax
    Example
    Create Graphic Element using CIMGraphic
      //Note: on the QueuedTask
      //Place symbol on the layout
      MapPoint location = MapPointBuilderEx.CreateMapPoint(new Coordinate2D(9, 1));
      //specify a symbol
      var pt_symbol = SymbolFactory.Instance.ConstructPointSymbol(
                            ColorFactory.Instance.GreenRGB);
      //create a CIMGraphic
      var graphic = new CIMPointGraphic()
        Symbol = pt_symbol.MakeSymbolReference(),
        Location = location //center of map
      //Or use GraphicFactory
      var graphicFactory = GraphicFactory.Instance.CreateSimpleGraphic(location, pt_symbol);
      ElementFactory.Instance.CreateGraphicElement(layout, graphic);
      ElementFactory.Instance.CreateGraphicElement(layout, graphicFactory);
    Create Element using a CIMGraphicElement
      //Note: Must be on QueuedTask.Run
      MapPoint point = MapPointBuilderEx.CreateMapPoint(new Coordinate2D(9, 1));
      //specify a symbol
      var graphic = new CIMGraphicElement()
        Graphic = new CIMPointGraphic()
          Location = point //A point in the layout
      ElementFactory.Instance.CreateElement(layout, graphic);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMElement
             ArcGIS.Core.CIM.CIMGraphicElement
                ArcGIS.Core.CIM.CIMVideoGraphicElement
    Requirements
