ArcGIS.Core.CIM Namespace / CIMKnowledgeGraphNamedTypeFilterByType Class
Members Example
    Represents a Knowledge Graph named type filter by type with optional property filter predicate.
    Object Model
    CIMKnowledgeGraphNamedTypeFilterByType ClassCIMKnowledgeGraphNamedTypeFilterByType ClassCIMKnowledgeGraphNamedTypeFilterByType Class
    Syntax
    Example
    Configure Centrality Entity SubGraph Filters
      //using ArcGIS.Core.Data.Knowledge.Extensions;
      await QueuedTask.Run(() =>
        //using(var kg = ....) {
        //Assume KG contains Entity NamedTypes "A","B","C", and "D"
        //We can use either of a CIMKnowledgeGraphNamedTypeFilterByInstances
        //or CIMKnowledgeGraphNamedTypeFilterByType to filter instances for
        //_including_ in or _excluding_ from entities and relates wrt the subgraph.
        //Use CIMKnowledgeGraphNamedTypeFilterByInstances to filter by instance id
        //Use CIMKnowledgeGraphNamedTypeFilterByType to filter by type name and with
        //an optional property filter predicate to filter by property value(s)
        //Example 1.
        //Include all entities (and relates) from the kg in the subgraph
        //Leave kg_subgraph.EntityFilters null.
        //(kg_subgraph.RelationshipFilters is also null)
        //The collection of Entity and Relate filters are both empty
        //Everything is included
        var kg_subgraph = new CIMKnowledgeGraphSubGraph();
        //Example 2
        //Include a set of Entities from A (all of B, C, D will be implicitly excluded)
        var kg_filter2 = new CIMKnowledgeGraphNamedTypeFilterByInstances()
          FilterType = KGFilterType.Include,
          NamedType = "A",
          InstancesIDs = list_of_ids.ToArray() //list_of_ids contains desired uids for "A"
                                               //note: -if list_of_ids is empty then -no-
                                               //instances of A will be included.
        var entity_filters2 = new List<CIMKnowledgeGraphNamedTypeFilter>();
        entity_filters2.Add(kg_filter2);
        //note: All relates are included as no RelationshipFilters are specified
        //var kg_subgraph = ...
        kg_subgraph.EntityFilters = entity_filters2.ToArray();
        //Example 3
        //Exclude a set of Entities from A (all of B, C, D will be implicitly included)
        var kg_filter3 = new CIMKnowledgeGraphNamedTypeFilterByInstances()
          FilterType = KGFilterType.Exclude,
          NamedType = "A",
                                               //instances of A will be excluded.
        var entity_filters3 = new List<CIMKnowledgeGraphNamedTypeFilter>();
        entity_filters3.Add(kg_filter3);
        kg_subgraph.EntityFilters = entity_filters3.ToArray();
        //Example 4
        //Include all Entities from A via named type (all of B, C, D
        //will be implicitly excluded)
        var kg_filter4 = new CIMKnowledgeGraphNamedTypeFilterByType()
          NamedType = "A" //all of A will be included
                          //predicate is empty
        var entity_filters4 = new List<CIMKnowledgeGraphNamedTypeFilter>();
        entity_filters4.Add(kg_filter4);
        kg_subgraph.EntityFilters = entity_filters4.ToArray();
        //Example 5
        //Exclude all Entities from A via named type (all of B, C, D
        //will be implicitly included)
        var kg_filter5 = new CIMKnowledgeGraphNamedTypeFilterByType()
          NamedType = "A" //all of A will be excluded
        var entity_filters5 = new List<CIMKnowledgeGraphNamedTypeFilter>();
        entity_filters5.Add(kg_filter5);
        kg_subgraph.EntityFilters = entity_filters5.ToArray();
        //Example 6
        //Include all entities from B and C and
        //a subset from D via a set of ids (A is implicitly excluded)
        var kg_filter6_b = new CIMKnowledgeGraphNamedTypeFilterByType();
        var kg_filter6_c = new CIMKnowledgeGraphNamedTypeFilterByType();
        kg_filter6_b.NamedType = "B";//Include is default, predicate is empty
        kg_filter6_c.NamedType = "C";//Include is default, predicate is empty
        //TODO... populate list with uids from "D"...
        var kg_filter6_d = new CIMKnowledgeGraphNamedTypeFilterByInstances();
        kg_filter6_d.NamedType = "D";//Include is default
        kg_filter6_d.InstancesIDs = list_of_ids.ToArray();
        var entity_filters6 = new List<CIMKnowledgeGraphNamedTypeFilter>();
        entity_filters6.Add(kg_filter6_b);//order doesn't matter
        entity_filters6.Add(kg_filter6_c);
        entity_filters6.Add(kg_filter6_d);
        kg_subgraph.EntityFilters = entity_filters6.ToArray();
        //Example 7
        //Exclude all entities from B and C and
        //a subset from D (A is implicitly included)
        var kg_filter7_b = new CIMKnowledgeGraphNamedTypeFilterByType();
        var kg_filter7_c = new CIMKnowledgeGraphNamedTypeFilterByType();
        kg_filter7_b.NamedType = "B";//predicate is empty
        kg_filter7_c.NamedType = "C";//predicate is empty
        kg_filter7_b.FilterType = KGFilterType.Exclude;
        kg_filter7_c.FilterType = KGFilterType.Exclude;
        var kg_filter7_d = new CIMKnowledgeGraphNamedTypeFilterByInstances();
        kg_filter7_d.NamedType = "D";
        kg_filter7_d.FilterType = KGFilterType.Exclude;
        kg_filter7_d.InstancesIDs = list_of_ids.ToArray();//ids to be excluded
        var entity_filters7 = new List<CIMKnowledgeGraphNamedTypeFilter>();
        entity_filters7.Add(kg_filter7_b);//order doesn't matter
        entity_filters7.Add(kg_filter7_c);
        entity_filters7.Add(kg_filter7_d);
        kg_subgraph.EntityFilters = entity_filters7.ToArray();
        //Example 8
        //Include a subset of Entities from A using a property
        //filter predicate (all of B, C, D will be implicitly excluded)
        //we -must- use a predicate prefix in our expression
        //select instances of A w/ Material = 'Steel'
        var expr8 = $"a.Material = 'Steel'";//prefix can be anything - foo, bar, fred, etc.
        var kg_filter8 = new CIMKnowledgeGraphNamedTypeFilterByType()
          NamedType = "A",//Include is default
          PropertyFilterPredicate = expr8 //include ids w/Material='Steel'
        var entity_filters8 = new List<CIMKnowledgeGraphNamedTypeFilter>();
        entity_filters8.Add(kg_filter8);
        kg_subgraph.EntityFilters = entity_filters8.ToArray();
        //Example 9
        //Exclude a subset of Entities from A using a property
        //filter predicate (all of B, C, D will be implicitly included)
        //select instances of A with Material <> 'Steel'
        var expr9 = $"a.Material <> 'Steel'";//prefix can be anything - foo, bar, fred, etc.
        var kg_filter9 = new CIMKnowledgeGraphNamedTypeFilterByType()
          NamedType = "A",
          PropertyFilterPredicate = expr9 //exclude ids w/Material <> 'Steel'
        var entity_filters9 = new List<CIMKnowledgeGraphNamedTypeFilter>();
        entity_filters9.Add(kg_filter9);
        //Note: All relates are included as no RelationshipFilters are specified
        kg_subgraph.EntityFilters = entity_filters9.ToArray();
    Configure Centrality Relationship SubGraph Filters
        //using(var kg = ...) {
        //Assume Relationship NamedTypes "R1","R2",and "R3"
        //Example 1.
        //Include all relates (and entities) from the kg in the subgraph
        //Leave kg_subgraph.RelationshipFilters null
        //(kg_subgraph.EntityFilters is also null)
        //note - relates can only be included if their corresponding entity end points
        //are also included in the subgraph.
        //Example 2
        //Include a set of Relates from R1 (all of R2, R3 will be implicitly excluded)
        var kg_filter_r2 = new CIMKnowledgeGraphNamedTypeFilterByInstances()
          NamedType = "R1",
          InstancesIDs = list_of_ids.ToArray() //list_of_ids contains desired uids for "R1"
                                               //instances of R1 will be included.
        var relate_filters2 = new List<CIMKnowledgeGraphNamedTypeFilter>();
        relate_filters2.Add(kg_filter_r2);
        //note: All entities are included as no EntityFilters are specified
        kg_subgraph.RelationshipFilters = relate_filters2.ToArray();
        //Example 3
        //Exclude a set of Relates from R1 (all of R2, R3 will be implicitly included)
        var kg_filter_r3 = new CIMKnowledgeGraphNamedTypeFilterByInstances()
          NamedType = "R1",
                                               //instances of R1 will be excluded.
        var relate_filters3 = new List<CIMKnowledgeGraphNamedTypeFilter>();
        relate_filters3.Add(kg_filter_r3);
        kg_subgraph.RelationshipFilters = relate_filters3.ToArray();
        //Example 4
        //Include all Relates from R1 via named type (all of R2, R3
        var kg_filter_r4 = new CIMKnowledgeGraphNamedTypeFilterByType()
          NamedType = "R1",//all of R1 will be included
        var relate_filters4 = new List<CIMKnowledgeGraphNamedTypeFilter>();
        relate_filters4.Add(kg_filter_r4);
        kg_subgraph.RelationshipFilters = relate_filters4.ToArray();
        //Example 5
        //Exclude all Relates from R1 via named type (all of R2, R3
        var kg_filter_r5 = new CIMKnowledgeGraphNamedTypeFilterByType()
          NamedType = "R1" //all of R1 will be excluded
        var relate_filters5 = new List<CIMKnowledgeGraphNamedTypeFilter>();
        relate_filters5.Add(kg_filter_r5);
        kg_subgraph.RelationshipFilters = relate_filters5.ToArray();
        //Example 6
        //Include all relates from R2 and
        //a subset from R3 (R1 is implicitly excluded)
        var kg_filter_r6_r2 = new CIMKnowledgeGraphNamedTypeFilterByType();
        kg_filter_r6_r2.NamedType = "R2"; //Include is default, predicate is empty
        //TODO... populate list with uids from "R3"...
        var kg_filter_r6_r3 = new CIMKnowledgeGraphNamedTypeFilterByInstances();
        kg_filter_r6_r3.NamedType = "R3"; //Include is default
        kg_filter_r6_r3.InstancesIDs = list_of_ids.ToArray();
        var relate_filters6 = new List<CIMKnowledgeGraphNamedTypeFilter>();
        relate_filters6.Add(kg_filter_r6_r2);//order doesn't matter
        relate_filters6.Add(kg_filter_r6_r3);
        kg_subgraph.RelationshipFilters = relate_filters6.ToArray();
        //Example 7
        //Exclude all relates from R2 and
        //a subset from R3 (R1 is implicitly included)
        var kg_filter_r7_r2 = new CIMKnowledgeGraphNamedTypeFilterByType();
        kg_filter_r7_r2.NamedType = "R2";
        kg_filter_r7_r2.FilterType = KGFilterType.Exclude;
        var kg_filter_r7_r3 = new CIMKnowledgeGraphNamedTypeFilterByInstances();
        kg_filter_r7_r3.NamedType = "R3";
        kg_filter_r7_r3.FilterType = KGFilterType.Exclude;
        kg_filter_r7_r3.InstancesIDs = list_of_ids.ToArray();
        var relate_filters7 = new List<CIMKnowledgeGraphNamedTypeFilter>();
        relate_filters7.Add(kg_filter_r7_r2);//order doesn't matter
        relate_filters7.Add(kg_filter_r7_r3);
        //Example 8
        //Include a subset of Relates from R1 using a property
        //filter predicate (all of R2, R3 will be implicitly excluded)
        //select instances of R1 w/Distance = 2000
        var expr8 = $"r1.Distance = 2000";//prefix can be anything - foo, bar, fred, etc.
        var kg_filter_r8 = new CIMKnowledgeGraphNamedTypeFilterByType()
          NamedType = "R1", //Include is default
        var relate_filters8 = new List<CIMKnowledgeGraphNamedTypeFilter>();
        relate_filters8.Add(kg_filter_r8);
        kg_subgraph.RelationshipFilters = relate_filters8.ToArray();
        //Example 9
        //Exclude a subset of Relates from R1 using a property
        //filter predicate (all of R2, R3 will be implicitly included)
        //select instances of R1 w/ Distance <> 2000
        var expr9 = $"r1.Distance <> 2000";//prefix can be anything - foo, bar, fred, etc.
        var kg_filter_r9 = new CIMKnowledgeGraphNamedTypeFilterByType()
          NamedType = "R1",
          PropertyFilterPredicate = expr9 //exclude ids w/ Distance <> 2000
        var relate_filters9 = new List<CIMKnowledgeGraphNamedTypeFilter>();
        relate_filters9.Add(kg_filter_r9);
        //Note: All entities are included as no EntityFilters are specified
        kg_subgraph.RelationshipFilters = relate_filters9.ToArray();
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMKnowledgeGraphNamedTypeFilter
             ArcGIS.Core.CIM.CIMKnowledgeGraphNamedTypeFilterByType
    Requirements
    ArcGIS Pro version: 3.6 or higher.
