ArcGIS.Core.CIM Namespace / CIMKnowledgeGraphNamedTypeFilterByType Class
Properties Methods Events
    CIMKnowledgeGraphNamedTypeFilterByType Class Members
    The following tables list the members exposed by CIMKnowledgeGraphNamedTypeFilterByType.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the filter type, i.e whether to include or exclude the instances represented by the filter. (Inherited from ArcGIS.Core.CIM.CIMKnowledgeGraphNamedTypeFilter)
    Public Property Gets or sets the named type (an entity type or a relationship type). (Inherited from ArcGIS.Core.CIM.CIMKnowledgeGraphNamedTypeFilter)
    Public Property Gets or sets the property filter predicate (openCypher syntax) associated with the filter.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMKnowledgeGraphNamedTypeFilterByType.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMKnowledgeGraphNamedTypeFilterByType with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMKnowledgeGraphNamedTypeFilterByType and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
