//using ArcGIS.Core.Data.Knowledge.Extensions;
await QueuedTask.Run(() =>
//using(var kg = ....) {
//Assume KG contains Entity NamedTypes "A","B","C", and "D"
//We can use either of a CIMKnowledgeGraphNamedTypeFilterByInstances
//or CIMKnowledgeGraphNamedTypeFilterByType to filter instances for
//_including_ in or _excluding_ from entities and relates wrt the subgraph.
//Use CIMKnowledgeGraphNamedTypeFilterByInstances to filter by instance id
//Use CIMKnowledgeGraphNamedTypeFilterByType to filter by type name and with
//an optional property filter predicate to filter by property value(s)
//Example 1.
//Include all entities (and relates) from the kg in the subgraph
//Leave kg_subgraph.EntityFilters null.
//(kg_subgraph.RelationshipFilters is also null)
//The collection of Entity and Relate filters are both empty
//Everything is included
var kg_subgraph = new CIMKnowledgeGraphSubGraph();
//Example 2
//Include a set of Entities from A (all of B, C, D will be implicitly excluded)
var kg_filter2 = new CIMKnowledgeGraphNamedTypeFilterByInstances()
FilterType = KGFilterType.Include,
NamedType = "A",
InstancesIDs = list_of_ids.ToArray() //list_of_ids contains desired uids for "A"
//note: -if list_of_ids is empty then -no-
//instances of A will be included.
var entity_filters2 = new List<CIMKnowledgeGraphNamedTypeFilter>();
entity_filters2.Add(kg_filter2);
//note: All relates are included as no RelationshipFilters are specified
//var kg_subgraph = ...
kg_subgraph.EntityFilters = entity_filters2.ToArray();
//Example 3
//Exclude a set of Entities from A (all of B, C, D will be implicitly included)
var kg_filter3 = new CIMKnowledgeGraphNamedTypeFilterByInstances()
FilterType = KGFilterType.Exclude,
NamedType = "A",
//instances of A will be excluded.
var entity_filters3 = new List<CIMKnowledgeGraphNamedTypeFilter>();
entity_filters3.Add(kg_filter3);
kg_subgraph.EntityFilters = entity_filters3.ToArray();
//Example 4
//Include all Entities from A via named type (all of B, C, D
//will be implicitly excluded)
var kg_filter4 = new CIMKnowledgeGraphNamedTypeFilterByType()
NamedType = "A" //all of A will be included
//predicate is empty
var entity_filters4 = new List<CIMKnowledgeGraphNamedTypeFilter>();
entity_filters4.Add(kg_filter4);
kg_subgraph.EntityFilters = entity_filters4.ToArray();
//Example 5
//Exclude all Entities from A via named type (all of B, C, D
//will be implicitly included)
var kg_filter5 = new CIMKnowledgeGraphNamedTypeFilterByType()
NamedType = "A" //all of A will be excluded
var entity_filters5 = new List<CIMKnowledgeGraphNamedTypeFilter>();
entity_filters5.Add(kg_filter5);
kg_subgraph.EntityFilters = entity_filters5.ToArray();
//Example 6
//Include all entities from B and C and
//a subset from D via a set of ids (A is implicitly excluded)
var kg_filter6_b = new CIMKnowledgeGraphNamedTypeFilterByType();
var kg_filter6_c = new CIMKnowledgeGraphNamedTypeFilterByType();
kg_filter6_b.NamedType = "B";//Include is default, predicate is empty
kg_filter6_c.NamedType = "C";//Include is default, predicate is empty
//TODO... populate list with uids from "D"...
var kg_filter6_d = new CIMKnowledgeGraphNamedTypeFilterByInstances();
kg_filter6_d.NamedType = "D";//Include is default
kg_filter6_d.InstancesIDs = list_of_ids.ToArray();
var entity_filters6 = new List<CIMKnowledgeGraphNamedTypeFilter>();
entity_filters6.Add(kg_filter6_b);//order doesn't matter
entity_filters6.Add(kg_filter6_c);
entity_filters6.Add(kg_filter6_d);
kg_subgraph.EntityFilters = entity_filters6.ToArray();
//Example 7
//Exclude all entities from B and C and
//a subset from D (A is implicitly included)
var kg_filter7_b = new CIMKnowledgeGraphNamedTypeFilterByType();
var kg_filter7_c = new CIMKnowledgeGraphNamedTypeFilterByType();
kg_filter7_b.NamedType = "B";//predicate is empty
kg_filter7_c.NamedType = "C";//predicate is empty
kg_filter7_b.FilterType = KGFilterType.Exclude;
kg_filter7_c.FilterType = KGFilterType.Exclude;
var kg_filter7_d = new CIMKnowledgeGraphNamedTypeFilterByInstances();
kg_filter7_d.NamedType = "D";
kg_filter7_d.FilterType = KGFilterType.Exclude;
kg_filter7_d.InstancesIDs = list_of_ids.ToArray();//ids to be excluded
var entity_filters7 = new List<CIMKnowledgeGraphNamedTypeFilter>();
entity_filters7.Add(kg_filter7_b);//order doesn't matter
entity_filters7.Add(kg_filter7_c);
entity_filters7.Add(kg_filter7_d);
kg_subgraph.EntityFilters = entity_filters7.ToArray();
//Example 8
//Include a subset of Entities from A using a property
//filter predicate (all of B, C, D will be implicitly excluded)
//we -must- use a predicate prefix in our expression
//select instances of A w/ Material = 'Steel'
var expr8 = $"a.Material = 'Steel'";//prefix can be anything - foo, bar, fred, etc.
var kg_filter8 = new CIMKnowledgeGraphNamedTypeFilterByType()
NamedType = "A",//Include is default
PropertyFilterPredicate = expr8 //include ids w/Material='Steel'
var entity_filters8 = new List<CIMKnowledgeGraphNamedTypeFilter>();
entity_filters8.Add(kg_filter8);
kg_subgraph.EntityFilters = entity_filters8.ToArray();
//Example 9
//Exclude a subset of Entities from A using a property
//filter predicate (all of B, C, D will be implicitly included)
//select instances of A with Material <> 'Steel'
var expr9 = $"a.Material <> 'Steel'";//prefix can be anything - foo, bar, fred, etc.
var kg_filter9 = new CIMKnowledgeGraphNamedTypeFilterByType()
NamedType = "A",
PropertyFilterPredicate = expr9 //exclude ids w/Material <> 'Steel'
var entity_filters9 = new List<CIMKnowledgeGraphNamedTypeFilter>();
entity_filters9.Add(kg_filter9);
//Note: All relates are included as no RelationshipFilters are specified
kg_subgraph.EntityFilters = entity_filters9.ToArray();
//using(var kg = ...) {
//Assume Relationship NamedTypes "R1","R2",and "R3"
//Example 1.
//Include all relates (and entities) from the kg in the subgraph
//Leave kg_subgraph.RelationshipFilters null
//(kg_subgraph.EntityFilters is also null)
//note - relates can only be included if their corresponding entity end points
//are also included in the subgraph.
//Example 2
//Include a set of Relates from R1 (all of R2, R3 will be implicitly excluded)
var kg_filter_r2 = new CIMKnowledgeGraphNamedTypeFilterByInstances()
NamedType = "R1",
InstancesIDs = list_of_ids.ToArray() //list_of_ids contains desired uids for "R1"
//instances of R1 will be included.
var relate_filters2 = new List<CIMKnowledgeGraphNamedTypeFilter>();
relate_filters2.Add(kg_filter_r2);
//note: All entities are included as no EntityFilters are specified
kg_subgraph.RelationshipFilters = relate_filters2.ToArray();
//Example 3
//Exclude a set of Relates from R1 (all of R2, R3 will be implicitly included)
var kg_filter_r3 = new CIMKnowledgeGraphNamedTypeFilterByInstances()
NamedType = "R1",
//instances of R1 will be excluded.
var relate_filters3 = new List<CIMKnowledgeGraphNamedTypeFilter>();
relate_filters3.Add(kg_filter_r3);
kg_subgraph.RelationshipFilters = relate_filters3.ToArray();
//Example 4
//Include all Relates from R1 via named type (all of R2, R3
var kg_filter_r4 = new CIMKnowledgeGraphNamedTypeFilterByType()
NamedType = "R1",//all of R1 will be included
var relate_filters4 = new List<CIMKnowledgeGraphNamedTypeFilter>();
relate_filters4.Add(kg_filter_r4);
kg_subgraph.RelationshipFilters = relate_filters4.ToArray();
//Example 5
//Exclude all Relates from R1 via named type (all of R2, R3
var kg_filter_r5 = new CIMKnowledgeGraphNamedTypeFilterByType()
NamedType = "R1" //all of R1 will be excluded
var relate_filters5 = new List<CIMKnowledgeGraphNamedTypeFilter>();
relate_filters5.Add(kg_filter_r5);
kg_subgraph.RelationshipFilters = relate_filters5.ToArray();
//Example 6
//Include all relates from R2 and
//a subset from R3 (R1 is implicitly excluded)
var kg_filter_r6_r2 = new CIMKnowledgeGraphNamedTypeFilterByType();
kg_filter_r6_r2.NamedType = "R2"; //Include is default, predicate is empty
//TODO... populate list with uids from "R3"...
var kg_filter_r6_r3 = new CIMKnowledgeGraphNamedTypeFilterByInstances();
kg_filter_r6_r3.NamedType = "R3"; //Include is default
kg_filter_r6_r3.InstancesIDs = list_of_ids.ToArray();
var relate_filters6 = new List<CIMKnowledgeGraphNamedTypeFilter>();
relate_filters6.Add(kg_filter_r6_r2);//order doesn't matter
relate_filters6.Add(kg_filter_r6_r3);
kg_subgraph.RelationshipFilters = relate_filters6.ToArray();
//Example 7
//Exclude all relates from R2 and
//a subset from R3 (R1 is implicitly included)
var kg_filter_r7_r2 = new CIMKnowledgeGraphNamedTypeFilterByType();
kg_filter_r7_r2.NamedType = "R2";
kg_filter_r7_r2.FilterType = KGFilterType.Exclude;
var kg_filter_r7_r3 = new CIMKnowledgeGraphNamedTypeFilterByInstances();
kg_filter_r7_r3.NamedType = "R3";
kg_filter_r7_r3.FilterType = KGFilterType.Exclude;
kg_filter_r7_r3.InstancesIDs = list_of_ids.ToArray();
var relate_filters7 = new List<CIMKnowledgeGraphNamedTypeFilter>();
relate_filters7.Add(kg_filter_r7_r2);//order doesn't matter
relate_filters7.Add(kg_filter_r7_r3);
//Example 8
//Include a subset of Relates from R1 using a property
//filter predicate (all of R2, R3 will be implicitly excluded)
//select instances of R1 w/Distance = 2000
var expr8 = $"r1.Distance = 2000";//prefix can be anything - foo, bar, fred, etc.
var kg_filter_r8 = new CIMKnowledgeGraphNamedTypeFilterByType()
NamedType = "R1", //Include is default
var relate_filters8 = new List<CIMKnowledgeGraphNamedTypeFilter>();
relate_filters8.Add(kg_filter_r8);
kg_subgraph.RelationshipFilters = relate_filters8.ToArray();
//Example 9
//Exclude a subset of Relates from R1 using a property
//filter predicate (all of R2, R3 will be implicitly included)
//select instances of R1 w/ Distance <> 2000
var expr9 = $"r1.Distance <> 2000";//prefix can be anything - foo, bar, fred, etc.
var kg_filter_r9 = new CIMKnowledgeGraphNamedTypeFilterByType()
NamedType = "R1",
PropertyFilterPredicate = expr9 //exclude ids w/ Distance <> 2000
var relate_filters9 = new List<CIMKnowledgeGraphNamedTypeFilter>();
relate_filters9.Add(kg_filter_r9);
//Note: All entities are included as no EntityFilters are specified
kg_subgraph.RelationshipFilters = relate_filters9.ToArray();
