ArcGIS.Core.CIM Namespace / CIMPointCloudBitFieldFilter Class
Members Example
    Represents a point cloud bit field filter. Filters based on the bit-wise representation of the provided field. /// For a point to be retained, its attribute field bits must match /// BitsToSet and BitsToClear. Bits which are not explicitly clear nor /// set, are ignored.
    Object Model
    CIMPointCloudBitFieldFilter ClassCIMPointCloudBitFieldFilter ClassCIMPointCloudBitFieldFilter Class
    Syntax
    Example
    Get the filters for PointCloudSceneLayer
      // Note: call within QueuedTask.Run()
        IReadOnlyList<CIMPointCloudFilter> updatedFilter = pointCloudSceneLayer.GetFilters();
        foreach (var f in updatedFilter)
          //There is either 0 or 1 of each
          if (f is CIMPointCloudReturnFilter returnFilter)
            PointCloudFilterDefinition pcfl = PointCloudFilterDefinition.FromCIM(updatedFilter);
            List<PointCloudReturnType> updatedReturnValues = pcfl.ReturnValues;
          if (f is CIMPointCloudValueFilter classCodesFilter)
            // do something
          if (f is CIMPointCloudBitFieldFilter classFlagsFilter)
            // do something
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMPointCloudFilter
             ArcGIS.Core.CIM.CIMPointCloudBitFieldFilter
    Requirements
