ArcGIS.Core.CIM Namespace / CIMSizeVisualVariable Class
Members Example
    Represents a size visual variable.
    Object Model
    CIMSizeVisualVariable ClassCIMVisualVariableAuthoringInfo ClassCIMSizeVisualVariable ClassCIMSizeVisualVariable ClassCIMExpressionInfo ClassLinearUnit Class
    Syntax
    Remarks
    VariableType = Graduated use expression, Minimum/Maximum size, Minimum/Maximum value.
    VariableType = Proportional, unit defined use Expression, ValueUnit, ValueShape, ValueRepresentation.
    VariableType = Proportional, unit NOT defined use Expression, MinSize, MinValue, could use MaxSize.
    Example
    Evaluating Arcade Visual Variable Expressions on a Renderer
      //Consult https://github.com/Esri/arcade-expressions/ and
      //https://developers.arcgis.com/arcade/ for more examples
      //and arcade reference
      // Note: the following should be embedded in a QueuedTask.Run() statement
        //Assume we have a layer that is using Visual Variable
        //expressions that we want to evaluate interactively...
        var def = featureLayer.GetDefinition() as CIMFeatureLayer;
        //Most all feature renderers have a VisualVariable collection
        var renderer = def.Renderer as CIMUniqueValueRenderer;
        List<CIMVisualVariable> vis_variables = renderer.VisualVariables?.ToList() ??
        if (vis_variables.Count == 0)
          return;//there are none
        var vis_var_with_expr = new Dictionary<string, string>();
        //see if any are using expressions
        foreach (var vv in vis_variables)
          if (vv is CIMColorVisualVariable cvv)
            if (!string.IsNullOrEmpty(cvv.ValueExpressionInfo?.Expression))
              vis_var_with_expr.Add("Color", cvv.ValueExpressionInfo?.Expression);
          else if (vv is CIMTransparencyVisualVariable tvv)
            if (!string.IsNullOrEmpty(tvv.ValueExpressionInfo?.Expression))
              vis_var_with_expr.Add("Transparency", tvv.ValueExpressionInfo?.Expression);
          else if (vv is CIMSizeVisualVariable svv)
            if (!string.IsNullOrEmpty(svv.ValueExpressionInfo?.Expression))
              vis_var_with_expr.Add("Outline", svv.ValueExpressionInfo?.Expression);
        if (vis_var_with_expr.Count == 0)
          return;//there aren't any with expressions
        //loop through the features (outer)
        //per feature evaluate each visual variable.... (inner)
        //the converse is to loop through the expressions (outer)
        //then per feature evaluate the expression (inner)
        using RowCursor rc = featureLayer.Search();
        while (rc.MoveNext())
          foreach (var kvp in vis_var_with_expr)
            var expr_info = new CIMExpressionInfo()
              Expression = kvp.Value,
              ReturnType = ExpressionReturnType.Default
            //per feature eval each expression...
            using ArcadeEvaluator arcade = ArcadeScriptEngine.Instance.CreateEvaluator(
                                        expr_info, ArcadeProfile.Visualization);
            var variables = new List<KeyValuePair<string, object>>() {
                new("$feature", rc.Current)
            //note 2D maps can also have view scale...
            //...if necessary...
            if (mv.ViewingMode == MapViewingMode.Map)
              variables.Add(new("$view.scale", mv.Camera.Scale));
            var result = arcade.Evaluate(variables).GetResult().ToString();
            //output
            System.Diagnostics.Debug.WriteLine(
               $"[{rc.Current.GetObjectID()}] '{kvp.Key}': {result}");
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMVisualVariable
             ArcGIS.Core.CIM.CIMSizeVisualVariable
                ArcGIS.Core.CIM.CIMSizeClassBreaksVisualVariable
    Requirements
