Public MustInherit Class CIMVisualVariable Inherits CIMObject Implements System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
public abstract class CIMVisualVariable : CIMObject, System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
//Consult https://github.com/Esri/arcade-expressions/ and
//https://developers.arcgis.com/arcade/ for more examples
//and arcade reference
// Note: the following should be embedded in a QueuedTask.Run() statement
//Assume we have a layer that is using Visual Variable
//expressions that we want to evaluate interactively...
var def = featureLayer.GetDefinition() as CIMFeatureLayer;
//Most all feature renderers have a VisualVariable collection
var renderer = def.Renderer as CIMUniqueValueRenderer;
List<CIMVisualVariable> vis_variables = renderer.VisualVariables?.ToList() ??
if (vis_variables.Count == 0)
return;//there are none
var vis_var_with_expr = new Dictionary<string, string>();
//see if any are using expressions
foreach (var vv in vis_variables)
if (vv is CIMColorVisualVariable cvv)
if (!string.IsNullOrEmpty(cvv.ValueExpressionInfo?.Expression))
vis_var_with_expr.Add("Color", cvv.ValueExpressionInfo?.Expression);
else if (vv is CIMTransparencyVisualVariable tvv)
if (!string.IsNullOrEmpty(tvv.ValueExpressionInfo?.Expression))
vis_var_with_expr.Add("Transparency", tvv.ValueExpressionInfo?.Expression);
else if (vv is CIMSizeVisualVariable svv)
if (!string.IsNullOrEmpty(svv.ValueExpressionInfo?.Expression))
vis_var_with_expr.Add("Outline", svv.ValueExpressionInfo?.Expression);
if (vis_var_with_expr.Count == 0)
return;//there aren't any with expressions
//loop through the features (outer)
//per feature evaluate each visual variable.... (inner)
//the converse is to loop through the expressions (outer)
//then per feature evaluate the expression (inner)
using RowCursor rc = featureLayer.Search();
while (rc.MoveNext())
foreach (var kvp in vis_var_with_expr)
var expr_info = new CIMExpressionInfo()
Expression = kvp.Value,
ReturnType = ExpressionReturnType.Default
//per feature eval each expression...
using ArcadeEvaluator arcade = ArcadeScriptEngine.Instance.CreateEvaluator(
expr_info, ArcadeProfile.Visualization);
var variables = new List<KeyValuePair<string, object>>() {
new("$feature", rc.Current)
//note 2D maps can also have view scale...
//...if necessary...
if (mv.ViewingMode == MapViewingMode.Map)
variables.Add(new("$view.scale", mv.Camera.Scale));
var result = arcade.Evaluate(variables).GetResult().ToString();
//output
System.Diagnostics.Debug.WriteLine(
$"[{rc.Current.GetObjectID()}] '{kvp.Key}': {result}");
/// <summary> /// Renders a feature layer using graduated colors to draw quantities. The outline width is varied based on attributes. ///  /// </summary> { //Check feature layer name //Code works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data var featureLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.Name == "USDemographics"); if (featureLayer == null) { MessageBox.Show("This renderer works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data", "Data missing"); } //Gets the first numeric field of the feature layer var firstNumericFieldOfFeatureLayer = "NumericFieldInFeatureLayer"; //Gets the min and max value of the field var minMax = GetFieldMinMax(featureLayer, firstNumericFieldOfFeatureLayer); GraduatedColorsRendererDefinition gcDef = new GraduatedColorsRendererDefinition() { ClassificationField = "NumericFieldInFeatureLayer", ClassificationMethod = ClassificationMethod.NaturalBreaks, BreakCount = 5, ColorRamp = colorRamp }; CIMClassBreaksRenderer renderer = (CIMClassBreaksRenderer)featureLayer.CreateRenderer(gcDef); //Create array of CIMVisualVariables to hold the outline information. var visualVariables = new CIMVisualVariable[] { new CIMSizeVisualVariable { ValueExpressionInfo = new CIMExpressionInfo { Title = "Custom", Expression = "$feature.AREA", ReturnType = ExpressionReturnType.Default }, AuthoringInfo = new CIMVisualVariableAuthoringInfo { MinSliderValue = Convert.ToDouble(minMax.Item1), MaxSliderValue = Convert.ToDouble(minMax.Item2), ShowLegend = false, Heading = firstNumericFieldOfFeatureLayer }, VariableType = SizeVisualVariableType.Graduated, Target = "outline", MinSize = 1, MaxSize = 13, MinValue = Convert.ToDouble(minMax.Item1), MaxValue = Convert.ToDouble(minMax.Item2) }, }; renderer.VisualVariables = visualVariables; //Note: Run within QueuedTask featureLayer?.SetRenderer(renderer); }
System.Object
ArcGIS.Core.CIM.CIMObject
ArcGIS.Core.CIM.CIMVisualVariable
ArcGIS.Core.CIM.CIMColorVisualVariable
ArcGIS.Core.CIM.CIMMultilevelVisualVariable
ArcGIS.Core.CIM.CIMRotationVisualVariable
ArcGIS.Core.CIM.CIMSizeVisualVariable
ArcGIS.Core.CIM.CIMTransparencyVisualVariable
