Public Class CIMRotationVisualVariable Inherits CIMVisualVariable Implements System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
public class CIMRotationVisualVariable : CIMVisualVariable, System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
//Note: needs to be called on the MCT
var cimRenderer = featureLayer.GetRenderer() as CIMUniqueValueRenderer;
//Gets the visual variables from the renderer
var cimRotationVariable = cimRenderer.VisualVariables.OfType<CIMRotationVisualVariable>().FirstOrDefault();
//Gets the visual variable info for the z dimension
var rotationInfoZ = cimRotationVariable.VisualVariableInfoZ;
//The Arcade expression used to evaluate and return the field name for the rotation
var rotationExpression = rotationInfoZ.ValueExpressionInfo.Expression; // this expression stores the field name
// get the CIM renderer from the layer
// Note: needs to be called on the MCT
var cimRenderer = featureLayer.GetRenderer() as ArcGIS.Core.CIM.CIMSimpleRenderer;
// get the collection of connected attributes for rotation
var cimRotationVariable = cimRenderer.VisualVariables.OfType<ArcGIS.Core.CIM.CIMRotationVisualVariable>().FirstOrDefault();
// the z direction is describing the heading rotation
var rotationExpression = rotationInfoZ.Expression; // this expression stores the field name
System.Object
ArcGIS.Core.CIM.CIMObject
ArcGIS.Core.CIM.CIMVisualVariable
