ArcGIS.Core.CIM Namespace / CIMRotationVisualVariable Class
Properties Methods Events
    CIMRotationVisualVariable Class Members
    The following tables list the members exposed by CIMRotationVisualVariable.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the authoring info. (Inherited from ArcGIS.Core.CIM.CIMVisualVariable)
    Public Property Gets or sets a value indicating whether the normal to surface value which applies to 3D views. If true, rotation is applied after marker is rotated normal to the 3D surface. If false, all rotations are applied starting from zeroed X, Y, Z rotation.
    Public Property Gets or sets the Z rotation type.
    Public Property Gets or sets the visual variable info for the X dimension.
    Public Property Gets or sets the visual variable info for the Y dimension.
    Public Property Gets or sets the visual variable info for the Z dimension.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMRotationVisualVariable.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMRotationVisualVariable with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMRotationVisualVariable and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
