ArcGIS.Core.CIM Namespace / CIMSizeVisualVariable Class
Properties Methods Events
    CIMSizeVisualVariable Class Members
    The following tables list the members exposed by CIMSizeVisualVariable.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the authoring info. (Inherited from ArcGIS.Core.CIM.CIMVisualVariable)
    Public Property Gets or sets size visual variable axis.
    Public Property Gets or sets the data values.
    Public Property Gets or sets the expression.
    Public Property Gets or sets the maximum size.
    Public Property Gets or sets the maximum value.
    Public Property Gets or sets the minimum size.
    Public Property Gets or sets the minimum value.
    Public Property Gets or sets the normalization field.
    Public Property Gets or sets the data normalization method.
    Public Property Gets or sets the random maximum.
    Public Property Gets or sets the random minimum.
    Public Property Gets or sets the size values that correspond to data values.
    Public Property Gets or sets size visual variable target which specifies the portion of the symbol targeted for sizing.
    Public Property Gets or sets ExpressionInfo that contains the Arcade expression that returns value as a number.
    Public Property Gets or sets the value representations.
    Public Property Gets or sets the value shape.
    Public Property Gets or sets the size visual variable type.
    Public Property Gets or sets size visual variable type.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMSizeVisualVariable.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMSizeVisualVariable with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMSizeVisualVariable and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
