ArcGIS.Core.CIM Namespace / CIMSqlQueryDataConnection Class
Members Example
    Represents a SQL query data connection.
    Object Model
    CIMSqlQueryDataConnection ClassCIMSqlQueryDataConnection ClassEnvelope ClassCIMSqlQueryDataConnection ClassCIMMaterializedViewProperties ClassSpatialReference Class
    Syntax
    Example
    Create a query layer
        Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri(@"C:\Connections\mySDE.sde")));
        CIMSqlQueryDataConnection sqldc = new CIMSqlQueryDataConnection()
            WorkspaceConnectionString = geodatabase.GetConnectionString(),
            GeometryType = esriGeometryType.esriGeometryPolygon,
            OIDFields = "OBJECTID",
            Srid = "102008",
            SqlQuery = "select * from MySDE.dbo.STATES",
            Dataset = "States"
        var lcp = new LayerCreationParams(sqldc)
            Name = "States"
        //Note: Needs QueuedTask to run
        FeatureLayer flyr = LayerFactory.Instance.CreateLayer<FeatureLayer>(lcp, map);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMDataConnection
             ArcGIS.Core.CIM.CIMSqlQueryDataConnection
    Requirements
