ArcGIS.Core.CIM Namespace / CIMSqlQueryDataConnection Class
Properties Methods Events
    CIMSqlQueryDataConnection Class Members
    The following tables list the members exposed by CIMSqlQueryDataConnection.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the classID of the custom workspace factory.
    Public Property Gets or sets the dataset name.
    Public Property Gets or sets the dataset type.
    Public Property Gets or sets the extent.
    Public Property Gets or sets the geometry type.
    Public Property Gets or sets a value indicating whether the query is "table based" (retrieves all the columns from the table and has no where clause or postfix clause).
    Public Property Gets or sets a value indicating whether the auto generated Esri OID field will be 32-bit or 64-bit.
    Public Property Gets or sets the properties relevant to materialized view-based query layers.
    Public Property Gets or sets the OID fields.
    Public Property Gets or sets the spatial index dimension.
    Public Property Gets or sets the spatial reference.
    Public Property Gets or sets the spatial storage type.
    Public Property Gets or sets the SQL query.
    Public Property Gets or sets the SRID of the spatial reference.
    Public Property Gets or sets the SRID type.
    Public Property Gets or sets the workspace connection string.
    Public Property Gets or sets the workspace factory.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMSqlQueryDataConnection.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMSqlQueryDataConnection with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMSqlQueryDataConnection and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
