ArcGIS.Core.CIM Namespace / CIMSqlQueryDataConnection Class / SqlQuery Property
Example
    SqlQuery Property (CIMSqlQueryDataConnection)
    Gets or sets the SQL query.
    Syntax
    public string SqlQuery {get; set;}
    Public Property SqlQuery As String
    Example
    Create a query layer
      Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri(@"C:\Connections\mySDE.sde")));
      CIMSqlQueryDataConnection sqldc = new CIMSqlQueryDataConnection()
        WorkspaceConnectionString = geodatabase.GetConnectionString(),
        GeometryType = esriGeometryType.esriGeometryPolygon,
        OIDFields = "OBJECTID",
        Srid = "102008",
        SqlQuery = "select * from MySDE.dbo.STATES",
        Dataset = "States"
      var lcp = new LayerCreationParams(sqldc)
        Name = "States"
      FeatureLayer flyr = await QueuedTask.Run(() =>
        LayerFactory.Instance.CreateLayer<FeatureLayer>(lcp, map));
    Requirements
