ArcGIS.Core.CIM Namespace / RasterMosaicMethod Enumeration
Example Example
    Raster mosaic methods.
    Syntax
    Members
    MemberDescription
    Attribute Attribute.
    Center Center.
    LockRaster Lock raster.
    Nadir Nadir.
    None None.
    Northwest Northwest.
    Seamline Seamline.
    Viewpoint Viewpoint.
    Example
    Update the sort order - mosaic method on a mosaic layer
        //Note: needs to be called on the QueuedTask
        // Get the image sub-layer from the mosaic layer.
        ImageServiceLayer mosaicImageSubLayer = mosaicLayer.GetImageLayer();
        // Get the mosaic rule.
        CIMMosaicRule mosaicingRule = mosaicImageSubLayer.GetMosaicRule();
        // Set the Mosaic Method to Center.
        mosaicingRule.MosaicMethod = RasterMosaicMethod.Center;
        // Update the mosaic with the changed mosaic rule.
        mosaicImageSubLayer.SetMosaicRule(mosaicingRule);
    Update the sort order - mosaic method on an image service layer
        // Get the mosaic rule of the image service.
        CIMMosaicRule mosaicRule = imageServiceLayer.GetMosaicRule();
        mosaicRule.MosaicMethod = RasterMosaicMethod.Center;
        // Update the image service with the changed mosaic rule.
        imageServiceLayer.SetMosaicRule(mosaicRule);
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.CIM.RasterMosaicMethod
    Requirements
