ArcGIS.Core.CIM Namespace / CIMKnowledgeGraphSpatialMergeWithinDistance Class
Members
    Represents merging geometries within a specified distance. The properties define a buffer which is used to perform an intersection. The buffers are always created in the coordinate system of the import data. If the import data has a geographic coordinate system, and the DistanceUnit is a Linear Unit, geodesic buffers will be created. Otherwise, planar buffers will be created.
    Object Model
    CIMKnowledgeGraphSpatialMergeWithinDistance ClassCIMKnowledgeGraphSpatialMergeWithinDistance ClassUnit ClassCIMKnowledgeGraphSpatialMergeWithinDistance Class
    Syntax
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMKnowledgeGraphSpatialMerge
             ArcGIS.Core.CIM.CIMKnowledgeGraphSpatialMergeWithinDistance
    Requirements
    ArcGIS Pro version: 3.6 or higher.
