ArcGIS.Core.CIM Namespace / ExtentFitType Enumeration
Example Example
    Extent fit types.
    Syntax
    Members
    MemberDescription
    BestFit Best fit.
    DataDriven Data driven.
    ExtentCenter Center the extent.
    Example
    Create a new spatial map series
      // This example create a new spatial map series and then applies it to the active layout. This will automatically
      // overwrite an existing map series if one is already present.
      //Note: Must be on QueuedTask.Run;
      //SpatialMapSeries constructor - required parameters
      BasicFeatureLayer indexLyr = map.FindLayers("Countries").FirstOrDefault() as BasicFeatureLayer;
      SpatialMapSeries SMS = MapSeries.CreateSpatialMapSeries(layout, mapFrame, indexLyr, "Name");
      //Set optional, non-default values
      SMS.CategoryField = "Continent";
      SMS.SortField = "Population";
      SMS.ExtentOptions = ExtentFitType.BestFit;
      SMS.MarginType = ArcGIS.Core.CIM.UnitType.PageUnits;
      SMS.MarginUnits = ArcGIS.Core.Geometry.LinearUnit.Centimeters;
      SMS.Margin = 1;
      SMS.ScaleRounding = 1000;
      layout.SetMapSeries(SMS);  //Overwrite existing map series.
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.CIM.ExtentFitType
    Requirements
