Public Class CIMProceduralSymbolLayer Inherits CIMSymbolLayer Implements System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
public class CIMProceduralSymbolLayer : CIMSymbolLayer, System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
/// <summary> /// Creates Mesh procedural symbol with various textures. ///  /// Note: The rule package used in this method can be obtained from the Sample Data included in the arcgis-pro-sdk-community-samples repository. /// </summary> { //Note: Run withing QueuedTask string _rulePkgPath = @"C:\Data\RulePackages\MultipatchTextures.rpk"; CIMSymbolLayer[] proceduralSymbolLyr = { new CIMProceduralSymbolLayer() { PrimitiveName = "Textures", RulePackage = _rulePkgPath, RulePackageName = "Textures", } }; var meshProceduralTextureSymbol = new CIMMeshSymbol() { SymbolLayers = proceduralSymbolLyr }; }
/// <summary> /// Create a procedural symbol that can be applied to a polygon building footprint layer ///  /// Note: The rule package used in this method can be obtained from the Sample Data included in the arcgis-pro-sdk-community-samples repository. /// </summary> { //Note: Run withing QueuedTask string _rulePkgPath = @"C:\Data\RulePackages\Venice_2014.rpk"; //Polygon symbol to hold the procedural layer var proceduralSymbol = SymbolFactory.Instance.ConstructPolygonSymbol(); //Array of layers to hold a procedural symbol layer CIMSymbolLayer[] proceduralSymbolLyr = { new CIMProceduralSymbolLayer() { PrimitiveName = "Venice Rule package 2014", RulePackage = _rulePkgPath, RulePackageName = "Venice_2014", } }; proceduralSymbol.SymbolLayers = proceduralSymbolLyr; //To apply the symbol to a polygon feature layer //var renderer = theLayer.GetRenderer() as CIMSimpleRenderer; //renderer.Symbol = proceduralSymbol.MakeSymbolReference(); //theLayer.SetRenderer(renderer); }
System.Object
ArcGIS.Core.CIM.CIMObject
ArcGIS.Core.CIM.CIMSymbolLayer
ArcGIS.Core.CIM.CIMProceduralSymbolLayer
