ArcGIS.Core.CIM Namespace / LASStretchAttribute Enumeration
Example Example
    LAS stretch attributes.
    Syntax
    Members
    MemberDescription
    Blue Blue.
    Elevation Elevation.
    GPSTime GPS time.
    Green Green.
    Intensity Intensity.
    NearInfrared Near infrared.
    None None.
    Red Red.
    RGB RGB.
    ScanAngle Scan angle.
    Example
    LAS Points Elevation Stretch Renderer
      var elevLasStretchRendererDef = new LasStretchRendererDefinition(ArcGIS.Core.CIM.LASStretchAttribute.Elevation);
      // accept the defaults for color ramp, etc
      if (lasDatasetLayer.CanCreateRenderer(elevLasStretchRendererDef))
        CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(elevLasStretchRendererDef);
        if (lasDatasetLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
          lasDatasetLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
      // OR use a stretch renderer with stretchType standard Deviations
      var elevLasStretchStdDevRendererDef = new LasStretchRendererDefinition(ArcGIS.Core.CIM.LASStretchAttribute.Elevation);
      elevLasStretchStdDevRendererDef.StretchType = LASStretchType.StandardDeviations;
      elevLasStretchStdDevRendererDef.NumberOfStandardDeviations = 2;
      // Note: Needs QueuedTask to run
        if (lasDatasetLayer.CanCreateRenderer(elevLasStretchStdDevRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(elevLasStretchStdDevRendererDef);
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
    Requirements
