ArcGIS.Core.CIM Namespace / AnimationTransition Enumeration
Example Example
    Specifies the method of transition for a value in a keyframe.
    Syntax
    Members
    MemberDescription
    AdjustableArc Value changes along a smooth curve to the end state. The tightness of the curve can be configured.
    FixedArc Value changes along a tightly controlled curve to the end state.
    Hold Value remains constant, equaling the previous keyframe's value.
    Hop Value increases, using a parabolic curve, beyond the end state before returning back to it. The height of the curve can be configured.
    Linear Value changes at a constant (linear) rate to the end state.
    None The keyframe value is ignored.
    Stepped Value switches to the end state at a specified point along the transition.
    Example
    Create Camera Keyframe
      var animation = mapView.Map.Animation;
      var cameraTrack = animation.Tracks.OfType<CameraTrack>().First(); //There will always be only 1 CameraTrack in the animation.
      cameraTrack.CreateKeyframe(mapView.Camera, atTime, AnimationTransition.FixedArc);
    Create Time Keyframe
      var timeTrack = animation.Tracks.OfType<TimeTrack>().First(); //There will always be only 1 TimeTrack in the animation.
      timeTrack.CreateKeyframe(mapView.Time, atTime, AnimationTransition.Linear);
    Create Range Keyframe
      var rangeTrack = animation.Tracks.OfType<RangeTrack>().First(); //There will always be only 1 RangeTrack in the animation.
      rangeTrack.CreateKeyframe(range, atTime, AnimationTransition.Linear);
    Create Layer Keyframe
      var layerTrack = animation.Tracks.OfType<LayerTrack>().First(); //There will always be only 1 LayerTrack in the animation.
      layerTrack.CreateKeyframe(layer, atTime, true, transparency, AnimationTransition.Linear);
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.CIM.AnimationTransition
    Requirements
