ArcGIS.Core.CIM Namespace / CIMPage Class
Members Example
    CIMPage Class
    Represents the page information associated with a layout.
    Object Model
    CIMPage ClassCIMPage ClassCIMPage ClassCIMMargin ClassCIMPrinterPreferences ClassLinearUnit Class
    Syntax
    Example
    Create a new layout using a modified CIM and open it
      //Create a new layout using a modified CIM and open it.
      //The CIM exposes additional members that may not be
      //available through the managed API.
      //In this example, optional guides are added.
      //Create a new CIMLayout on the worker thread
      //Note: Needs QueuedTask to run
      //Set up a CIM page
      CIMPage newPage = new CIMPage
        //required parameters
        Width = 8.5,
        Height = 11,
        Units = LinearUnit.Inches,
        //optional rulers
        ShowRulers = true,
        SmallestRulerDivision = 0.5,
        //optional guides
        ShowGuides = true
      CIMGuide guide1 = new CIMGuide
        Position = 1,
        Orientation = Orientation.Vertical
      CIMGuide guide2 = new CIMGuide
        Position = 6.5,
      CIMGuide guide3 = new CIMGuide
        Position = 1,
        Orientation = Orientation.Horizontal
      CIMGuide guide4 = new CIMGuide
        Position = 10,
      List<CIMGuide> guideList = new List<CIMGuide>
        guide1,
        guide2,
        guide3,
        guide4
      newPage.Guides = guideList.ToArray();
      //Construct the new layout using the customized cim definitions
      var layout_local = LayoutFactory.Instance.CreateLayout(newPage);
      layout_local.SetName("New 8.5x11 Layout");
      //Open new layout on the GUI thread
      await ProApp.Panes.CreateLayoutPaneAsync(layout_local);
    Change the layout page size
      //Change the layout page size.
      //Reference the layout project item
      LayoutProjectItem lytItem = Project.Current.GetItems<LayoutProjectItem>()
                             .FirstOrDefault(item => item.Name.Equals("MyLayoutItem"));
      if (layoutItem != null)
        //Get the layout
        Layout lyt = lytItem.GetLayout();
        if (lyt != null)
          //Change properties
          CIMPage page = lyt.GetPage();
          page.Width = 8.5;
          page.Height = 11;
          //Apply the changes to the layout
          lyt.SetPage(page);
    Create report
      //Note: Call within QueuedTask.Run()
      //The fields in the datasource used for the report
      //This uses a US Cities dataset
      var listFields = new List<CIMReportField> {
              //Grouping should be the first field
              new CIMReportField{Name = "STATE_NAME", FieldOrder = 0, Group = true, SortInfo = FieldSortInfo.Desc}, //Group cities using STATES
              new CIMReportField{Name = "CITY_NAME", FieldOrder = 1},
              new CIMReportField{Name = "POP1990", FieldOrder = 2, },
      //Definition query to use for the data source
      var defQuery = "STATE_NAME LIKE 'C%'";
      //Define the Datasource
      var reportDataSource = new ReportDataSource(featureLayer, defQuery, listFields);
      //The CIMPage defintion - page size, units, etc
      var cimReportPage = new CIMPage
        Height = 11,
        StretchElements = false,
        Width = 6.5,
        ShowRulers = true,
        ShowGuides = true,
        Margin = new CIMMargin { Bottom = 1, Left = 1, Right = 1, Top = 1 },
      //Report template
      var reportTemplates = await ReportTemplateManager.GetTemplatesAsync();
      var reportTemplate = reportTemplates.Where(r => r.Name == "Attribute List with Grouping").First();
      //Report Styling
      var reportStyles = await ReportStylingManager.GetStylingsAsync();
      var reportStyle = reportStyles.Where(s => s == "Cool Tones").First();
      //Field Statistics
      var fieldStatisticsList = new List<ReportFieldStatistic> {
              new ReportFieldStatistic{ Field = "POP1990", Statistic = FieldStatisticsFlag.Sum}
              //Note: NoStatistics option for FieldStatisticsFlag is not supported.
      var newReport = ReportFactory.Instance.CreateReport("USAReport", reportDataSource, cimReportPage, fieldStatisticsList, reportTemplate, reportStyle);
    Modify the report Page
        Height = 12,
        Width = 6.5,
        ShowRulers = true,
        ShowGuides = true,
      report.SetPage(cimReportPage);
      //Change only the report's page height
      report.SetPageHeight(12);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMPage
    Requirements
