ArcGIS.Core.CIM Namespace / KGMergePropertiesWithMissingData Enumeration
    Specifies the behavior when merge properties have missing data.
    Syntax
    Members
    MemberDescription
    CreateAndMerge Create or merge the item using the merge properties with missing data.
    CreateButDoNotMerge Create the item using the merge properties with missing data, but do not merge with it.
    DoNotCreateOrMerge Do not create or merge the item if any merge property has missing data.
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.CIM.KGMergePropertiesWithMissingData
    Requirements
    ArcGIS Pro version: 3.6 or higher.
