ArcGIS.Core.CIM Namespace / CIMCharacterMarker Class
Members Example
    Represents a character marker.
    Object Model
    CIMCharacterMarker ClassMapPoint ClassCIMCharacterMarker ClassCIMCharacterMarker ClassCIMMarkerPlacement ClassCIMPolygonSymbol Class
    Syntax
    Remarks
    The shape of a marker is defined by a glyph in a font. The marker is drawn using the specified size and color. Each marker has a defined frame around the glyph that is considered when the size is applied. As a result, character markers of the same size may appear different sizes if the glyphs frames are different sizes.
    Example
    Modify a point symbol created from a character marker
        //create marker from the Font, char index,size,color
        //Note: Needs QueuedTask to run
        var cimMarker = SymbolFactory.Instance.ConstructMarker(125, "Wingdings 3", "Regular", 6, ColorFactory.Instance.BlueRGB) as CIMCharacterMarker;
        var polygonMarker = cimMarker.Symbol;
        //modifying the polygon's outline and fill
        //This is the outline
        polygonMarker.SymbolLayers[0] = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.GreenRGB, 2, SimpleLineStyle.Solid);
        //This is the fill
        polygonMarker.SymbolLayers[1] = SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.BlueRGB);
        //create a symbol from the marker
        //Note this overload of ConstructPointSymbol does not need to be run within QueuedTask.Run.
        var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(cimMarker);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMSymbolLayer
             ArcGIS.Core.CIM.CIMMarker
                ArcGIS.Core.CIM.CIMCharacterMarker
    Requirements
