ArcGIS.Core.CIM Namespace / CIMParagraphTextGraphic Class
Members Example
    Represents a paragraph text graphic.
    Object Model
    CIMParagraphTextGraphic ClassCIMParagraphTextGraphic ClassCIMGraphicFrame ClassCIMParagraphTextGraphic ClassGeometry ClassCIMSymbolReference Class
    Syntax
    Example
    Create Rectangle Paragraph Text Element 1
      //Note: Must be on QueuedTask.Run
      //Create rectangle text with background and border symbology.
      //Build 2D polygon geometry
      List<Coordinate2D> plyCoords = new List<Coordinate2D>();
      plyCoords.Add(new Coordinate2D(3.5, 7));
      plyCoords.Add(new Coordinate2D(4.5, 7));
      plyCoords.Add(new Coordinate2D(4.5, 6.7));
      plyCoords.Add(new Coordinate2D(5.5, 6.7));
      plyCoords.Add(new Coordinate2D(5.5, 6.1));
      plyCoords.Add(new Coordinate2D(3.5, 6.1));
      Polygon poly = PolygonBuilderEx.CreatePolygon(plyCoords);
      //Set symbology, create and add element to layout
      //Also notice how formatting tags are using within the text string.
      CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
                        ColorFactory.Instance.GreyRGB, 10, "Arial", "Regular");
      string text = "Some Text String that is really long and is " +
                    "<BOL>forced to wrap to other lines</BOL> so that " +
                    "we can see the effects." as String;
      GraphicElement polyTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
        layout, TextType.RectangleParagraph, poly, sym, text, "Polygon Paragraph");
      //(Optionally) Modify paragraph border
      CIMGraphic polyTxtGra = polyTxtElm.GetGraphic();
      CIMParagraphTextGraphic cimPolyTxtGra = polyTxtGra as CIMParagraphTextGraphic;
      cimPolyTxtGra.Frame.BorderSymbol = new CIMSymbolReference();
      cimPolyTxtGra.Frame.BorderSymbol.Symbol =
                   SymbolFactory.Instance.ConstructLineSymbol(
                              ColorFactory.Instance.GreyRGB, 1.0, SimpleLineStyle.Solid);
      polyTxtElm.SetGraphic(polyTxtGra);
    Create a new field in the report
      //This is the gap between two fields
      double fieldIncrement = 0.9388875113593206276389;
      //On the QueuedTask
      //New field to add.
      var newReportField = new CIMReportField
        Name = "POP1990",
        FieldOrder = 2,
      //Get the "ReportSection element"
      var mainReportSection = report.Elements.OfType<ReportSection>().FirstOrDefault();
      if (mainReportSection == null) return;
      //Get the "ReportDetails" within the ReportSectionElement. ReportDetails is where "fields" are.
      var reportDetailsSection = mainReportSection?.Elements.OfType<ReportDetails>().FirstOrDefault();
      if (reportDetailsSection == null) return;
      //Within ReportDetails find the envelope that encloses a field.
      //We get the first CIMParagraphTextGraphic in the collection so that we can add the new field next to it.
      var lastFieldGraphic = reportDetailsSection.Elements.FirstOrDefault((r) =>
        var gr = r as GraphicElement;
        if (gr == null) return false;
        return (gr.GetGraphic() is CIMParagraphTextGraphic ? true : false);
      //Get the Envelope of the last field
      var graphicBounds = lastFieldGraphic.GetBounds();
      //Min and Max values of the envelope
      var xMinOfFieldEnvelope = graphicBounds.XMin;
      var yMinOfFieldEnvelope = graphicBounds.YMin;
      var xMaxOfFieldEnvelope = graphicBounds.XMax;
      var YMaxOfFieldEnvelope = graphicBounds.YMax;
      //create the new Envelope to be offset from the existing field
      MapPoint newMinPoint = MapPointBuilderEx.CreateMapPoint(xMinOfFieldEnvelope + fieldIncrement, yMinOfFieldEnvelope);
      MapPoint newMaxPoint = MapPointBuilderEx.CreateMapPoint(xMaxOfFieldEnvelope + fieldIncrement, YMaxOfFieldEnvelope);
      Envelope newFieldEnvelope = EnvelopeBuilderEx.CreateEnvelope(newMinPoint, newMaxPoint);
      //Create field
      GraphicElement fieldGraphic = ReportElementFactory.Instance.CreateFieldValueTextElement(reportDetailsSection, newFieldEnvelope, newReportField);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMGraphic
             ArcGIS.Core.CIM.CIMTextGraphicBase
                ArcGIS.Core.CIM.CIMParagraphTextGraphic
    Requirements
