ArcGIS.Core.CIM Namespace / CIMMaterialSymbolLayer Class
Members Example
    Represents a material which defines how the multipatch or mesh is drawn.
    Object Model
    CIMMaterialSymbolLayer ClassCIMMaterialSymbolLayer ClassCIMColor ClassCIMMaterialSymbolLayer Class
    Syntax
    Example
    Mesh material fill symbol
    /// <summary>
    /// Create a mesh symbol that can be applied to a multi-patch feature layer.
    /// A mesh symbol is a CIMMeshSymbol object.  Define an array of CIMSymbolLayers which contains a CIMMaterialSymbol layer with the specified properties such as Color, etc.
    /// Assign this array of CIMSymbolLayers to the CIMMeshSymbol.
    /// ![MeshSymbolOrange](https://ArcGIS.github.io/arcgis-pro-sdk/images/Symbology/mesh-material-orange.png)
    /// </summary>
      //Note: Run withing QueuedTask
      CIMSymbolLayer[] materialSymbolLayer =
                  new CIMMaterialSymbolLayer()
                      Color = ColorFactory.Instance.CreateRGBColor(230,152,0),
                      MaterialMode = MaterialMode.Multiply
      var meshMaterialFillSymbol = new CIMMeshSymbol()
        SymbolLayers = materialSymbolLayer
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMSymbolLayer
             ArcGIS.Core.CIM.CIMMaterialSymbolLayer
    Requirements
