MaplexGraticuleAlignmentType Enumeration
Modify Orientation of a label using the MaplexEngine - Points and Polygon geometry
// Note: call within QueuedTask.Run()
//Check if the label engine is Maplex or standard.
CIMGeneralPlacementProperties labelEngine = MapView.Active.Map.GetDefinition().GeneralPlacementProperties;
if (labelEngine is CIMStandardGeneralPlacementProperties)
return;
//Get the layer's definition
var lyrDefn = featureLayer.GetDefinition() as CIMFeatureLayer;
//Get the label classes - we need the first one
var listLabelClasses = lyrDefn.LabelClasses.ToList();
var theLabelClass = listLabelClasses.FirstOrDefault();
//Modify label Orientation
theLabelClass.MaplexLabelPlacementProperties.GraticuleAlignment = true;
theLabelClass.MaplexLabelPlacementProperties.GraticuleAlignmentType = MaplexGraticuleAlignmentType.Curved;
lyrDefn.LabelClasses = listLabelClasses.ToArray(); //Set the labelClasses back
featureLayer.SetDefinition(lyrDefn); //set the layer's definition
System.Object
System.ValueType
System.Enum
ArcGIS.Core.CIM.MaplexGraticuleAlignmentType
