ArcGIS.Core.CIM Namespace / GeometricEffectOffsetMethod Enumeration
    Geometric effect offset method which specifies the way the strokes or fills are displayed at corners.
    Syntax
    Members
    MemberDescription
    Bevelled Bevelled - follows the shortest straight path across a corner of the line or polygon.
    Mitered Mitered - matches the exact shape around a corner of the line or polygon.
    Rounded Rounded - follows a path of equal distance around a corner of the line or polygon.
    Square Square - follows a straight path across the corner of a line or polygon.
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.CIM.GeometricEffectOffsetMethod
    Requirements
