Public Class CIMUniqueValueGroup Inherits CIMObject Implements System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
public class CIMUniqueValueGroup : CIMObject, System.ComponentModel.INotifyPropertyChanged, System.Xml.Serialization.IXmlSerializable
//The goal is to construct the CIMUniqueValueRenderer which will be applied to the feature layer.
// To do this, the following are the objects we need to set the renderer up with the fields and symbols.
// As a reference, this is the USCities dataset. Snippet will create a unique value renderer that applies
// specific symbols to all the cities in California and Alabama. The rest of the cities will use a default symbol.
// First create a "CIMUniqueValueClass" for the cities in Alabama.
List<CIMUniqueValue> listUniqueValuesAlabama = new List<CIMUniqueValue> { new CIMUniqueValue { FieldValues = new string[] { "Alabama" } } };
CIMUniqueValueClass alabamaUniqueValueClass = new CIMUniqueValueClass
Editable = true,
Label = "Alabama",
Patch = PatchShape.Default,
Symbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB).MakeSymbolReference(),
Visible = true,
Values = listUniqueValuesAlabama.ToArray()
// Create a "CIMUniqueValueClass" for the cities in California.
List<CIMUniqueValue> listUniqueValuescalifornia = new List<CIMUniqueValue> { new CIMUniqueValue { FieldValues = new string[] { "California" } } };
CIMUniqueValueClass californiaUniqueValueClass = new CIMUniqueValueClass
Editable = true,
Label = "California",
Symbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.BlueRGB).MakeSymbolReference(),
Visible = true,
Values = listUniqueValuescalifornia.ToArray()
//Create a list of the above two CIMUniqueValueClasses
List<CIMUniqueValueClass> listUniqueValueClasses = new List<CIMUniqueValueClass>
alabamaUniqueValueClass, californiaUniqueValueClass
//Create a list of CIMUniqueValueGroup
CIMUniqueValueGroup uvg = new CIMUniqueValueGroup
Classes = listUniqueValueClasses.ToArray(),
List<CIMUniqueValueGroup> listUniqueValueGroups = new List<CIMUniqueValueGroup> { uvg };
//Create the CIMUniqueValueRenderer
CIMUniqueValueRenderer uvr = new CIMUniqueValueRenderer
UseDefaultSymbol = true,
DefaultLabel = "all other values",
DefaultSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreyRGB).MakeSymbolReference(),
Groups = listUniqueValueGroups.ToArray(),
Fields = new string[] { "STATE_NAME" }
//Set the feature layer's renderer.
//Note: Run within a QueuedTask
featureLayer.SetRenderer(uvr);
// Note: call within QueuedTask.Run()
var url = @"https://geoeventsample1.esri.com:6443/arcgis/rest/services/AirportTraffics/StreamServer";
var uri = new Uri(url, UriKind.Absolute);
var createParams = new FeatureLayerCreationParams(uri)
IsVisible = false
streamLayer = LayerFactory.Instance.CreateLayer<StreamLayer>(
createParams, map);
//Define the unique values by hand
var uvr = new CIMUniqueValueRenderer()
Fields = new string[] { "ACTYPE" },
DefaultLabel = "Others",
CIMColor.CreateRGBColor(185, 185, 185), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
var classes = new List<CIMUniqueValueClass>
//add in classes - one for ACTYPE of 727, one for DC 9
new CIMUniqueValueClass()
Values = new CIMUniqueValue[] {
new CIMUniqueValue() { FieldValues = new string[] { "B727" } } },
Visible = true,
Label = "Boeing 727",
ColorFactory.Instance.RedRGB, 10, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
new CIMUniqueValue() { FieldValues = new string[] { "DC9" } } },
Visible = true,
Label = "DC 9",
ColorFactory.Instance.GreenRGB, 10, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
//add the classes to a group
var groups = new List<CIMUniqueValueGroup>()
new CIMUniqueValueGroup() {
Classes = classes.ToArray()
//add the groups to the renderer
uvr.Groups = groups.ToArray();
//Apply the renderer (for current observations)
streamLayer.SetRenderer(uvr);
streamLayer.SetVisibility(true);//turn on the layer
//Define the classes by hand to avoid using CreateRenderer(...)
CIMUniqueValueClass uvcB727 = new CIMUniqueValueClass()
Values = new CIMUniqueValue[] { new CIMUniqueValue() { FieldValues = new string[] { "B727" } } },
Visible = true,
Symbol = SymbolFactory.Instance.ConstructPointSymbol(CIMColor.CreateRGBColor(255, 0, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
CIMUniqueValueClass uvcD9 = new CIMUniqueValueClass()
Values = new CIMUniqueValue[] { new CIMUniqueValue() { FieldValues = new string[] { "DC9" } } },
Visible = true,
Label = "DC 9",
Symbol = SymbolFactory.Instance.ConstructPointSymbol(CIMColor.CreateRGBColor(0, 255, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
//Assign the classes to a group
CIMUniqueValueGroup uvGrp = new CIMUniqueValueGroup()
Classes = new CIMUniqueValueClass[] { uvcB727, uvcD9 }
//assign the group to the renderer
var UVrndr = new CIMUniqueValueRenderer()
Groups = new CIMUniqueValueGroup[] { uvGrp },
//set the renderer. Depending on the current events received, the
//layer may or may not have events for each of the specified
//unique value classes
streamLayer.SetRenderer(UVrndr);
System.Object
ArcGIS.Core.CIM.CIMObject
ArcGIS.Core.CIM.CIMUniqueValueGroup
