ArcGIS.Core.CIM Namespace / CIMVoxelColorUniqueValue Class
Members Example
    Represents a voxel color unique value.
    Object Model
    CIMVoxelColorUniqueValue ClassCIMVoxelColorUniqueValue ClassCIMColor ClassCIMVoxelColorUniqueValue Class
    Syntax
    Example
    Change The Visibility on a CIMVoxelColorUniqueValue class
      await QueuedTask.Run(() =>
        //Get the variable profile whose renderer will be changed
        var variable = voxelLayer.SelectedVariableProfile;
        //Check DataType
        if (variable.DataType != VoxelVariableDataType.Discrete)
          return;//must be Discrete to have a UV Renderer...
        var renderer = variable.Renderer as CIMVoxelUniqueValueRenderer;
        //A CIMVoxelUniqueValueRenderer consists of a collection of
        //CIMVoxelColorUniqueValue classes - one per discrete value
        //in the associated variable profile value array
        //Get the first class
        var classes = renderer.Classes.ToList();
        var unique_value_class = classes.First();
        //Set its visibility off
        unique_value_class.Visible = false;
        //Apply the change to the renderer
        renderer.Classes = classes.ToArray();
        //apply the changes
        variable.SetRenderer(renderer);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMVoxelColorUniqueValue
    Requirements
