ArcGIS.Core.CIM Namespace / CIMChartMarkerSymbolProperties Class
Members Example
    Provides access to members that control properties of the marker symbol.
    Object Model
    CIMChartMarkerSymbolProperties ClassCIMChartMarkerSymbolProperties ClassCIMColor ClassCIMChartMarkerSymbolProperties ClassCIMChartLineSymbolProperties Class
    Syntax
    Example
    Create a line chart with custom time binning and style
      // For more information on the chart CIM specification:
      // https://github.com/Esri/cim-spec/blob/main/docs/v3/CIMCharts.md
      // Note: QueuedTask is required to access the feature layer
        var lyrDefLine = featureLayer.GetDefinition();
        // Define line chart CIM properties
        var lineChart = new CIMChart
          Name = "lineChart",
          GeneralProperties = new CIMChartGeneralProperties
            Title = $"Line chart for {dateField} summarized by {numericField}",
            UseAutomaticTitle = false
          Series =
                new CIMChartLineSeries {
                  UniqueName = "lineChartSeries",
                  Name = $"Sum({numericField})",
                  // Specify date field and numeric field
                  Fields = new string[] { dateField, numericField },
                  // Specify aggregation type
                  FieldAggregation = new string[] { string.Empty, "SUM" },
                  // Specify custom time bin of 6 months
                  TimeAggregationType = ChartTimeAggregationType.EqualIntervalsFromStartTime,
                  TimeIntervalSize = 6.0,
                  TimeIntervalUnits = esriTimeUnits.esriTimeUnitsMonths,
                  // NOTE: When setting custom time binning, be sure to set CalculateAutomaticTimeInterval = false
                  CalculateAutomaticTimeInterval = false,
                  // Define custom line color
                  ColorType = ChartColorType.CustomColor,
                  LineSymbolProperties = new CIMChartLineSymbolProperties {
                      Style = ChartLineDashStyle.DashDot,
                      Color = new CIMRGBColor { R = 0, G = 150, B = 20 },
                  MarkerSymbolProperties = new CIMChartMarkerSymbolProperties
        // Add new chart to layer's existing list of charts (if any exist)
        var newChartsLine = new CIMChart[] { lineChart };
        var allChartsLine = (lyrDefLine == null) ? newChartsLine : lyrDefLine.Charts.Concat(newChartsLine);
        // Add CIM chart to layer definition
        lyrDefLine.Charts = allChartsLine.ToArray();
        featureLayer.SetDefinition(lyrDefLine);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CIM.CIMObject
          ArcGIS.Core.CIM.CIMChartMarkerSymbolProperties
    Requirements
