ArcGIS.Desktop.Layouts Namespace / Layout Class / SetName Method
String
Example
    SetName Method (Layout)
    Sets the name of the layout. It is important that all layouts have a unique name so they can be easily referenced. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetName( _
       ByVal name As String _
    public void SetName(
       string name
    Parameters
    name
    String
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Example
    Create a new, basic layout and open it
      //Create a new, basic layout and open it.
      //Create layout with minimum set of parameters on the worker thread
      //Note: Needs QueuedTask to run
      var myNewLayout = LayoutFactory.Instance.CreateLayout(8.5, 11, LinearUnit.Inches);
      myNewLayout.SetName("New 8.5x11 Layout");
      //Open new layout on the GUI thread
      await ProApp.Panes.CreateLayoutPaneAsync(myNewLayout);
    Requirements
