ArcGIS.Desktop.Layouts Namespace / PictureElement Class / SetSourcePath Method
String
Example
    Regenerates the picture using the new file path to a picture on disk. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetSourcePath( _
       ByVal URI As String _
    public void SetSourcePath(
       string URI
    Parameters
    URI
    String
    Exceptions
    ExceptionDescription
    Example
    Update a picture element
      //Update a picture element.
      //Note: Must be on QueuedTask.Run
      // Reference a picture element by name
      PictureElement picElm = layout.FindElement("MyPicture") as PictureElement;
      // Change the path to a new source
      picElm?.SetSourcePath(@"D:\MyData\Pics\somePic.jpg");
    Requirements
