ArcGIS.Desktop.Layouts Namespace / LayoutView Class / CanActivateMapFrame Method
The mapframe to check
Example
    Check whether or not the given map frame can be activated on the layout view
    Syntax
    Public Function CanActivateMapFrame( _
       ByVal mapFrame As MapFrame _
    ) As Boolean
    public bool CanActivateMapFrame(
       MapFrame mapFrame
    Parameters
    mapFrame
    Return Value
    True if the map frame can be activated on this view
    Remarks
    To be activated, a map frame must have a valid map, be visible on the current layout (being shown on the view), and not already be activated. If another map frame is currently activated on the view then CanActivateMapFrame will also return false.
    Example
    Activate Map Frame
      //We can activate a map frame on the layout of the active view
      var map_frame = layout.GetElementsAsFlattenedList()
                          .OfType<MapFrame>().FirstOrDefault(mf => mf.Name == "Map 1");
      if (map_frame == null)
        return;
      //can we activate the map frame?
      if (layoutView.CanActivateMapFrame(map_frame))
        //activate it - Note: we are on the UI thread!
        layoutView.ActivateMapFrame(map_frame);
    Requirements
    ArcGIS Pro version: 3.1 or higher.
