ArcGIS.Desktop.Layouts Namespace / MapFrame Class
Members Example
    MapFrame Class
    Represents a map frame on a page layout.
    Object Model
    MapFrame ClassCamera ClassCoordinate2D StructureCIMAutoCamera ClassEnvelope ClassCIMElement ClassGeometry ClassMapView ClassIElementContainer InterfaceMapPoint ClassEnvelope ClassMap ClassCoordinate2D StructureCoordinate2D Structure
    Syntax
    Remarks
    The MapFrame class primarily manages the placement of maps and scenes on a page layout. You can use Map and SetMap members to get and set the Map associated with a MapFrame.
    The Export method allows you to export only the contents of a map frame instead of, for example, exporting an entire page layout.
    If you want to change the geographic extent within a map frame, you can use the Camera and SetCamera members to get and set the Camera associated with a MapFrame. SetCamera is an overloaded method that allows you to change the map frame extent to a camera position, a bookmark location, and so on.
    Example
    Create Map Frame and Set Camera
      //Create a map frame and set its camera by zooming to the extent of an existing bookmark.
      //Construct on the worker thread
      //Build 2D envelope geometry
      Coordinate2D mf_ll = new Coordinate2D(6.0, 8.5);
      Coordinate2D mf_ur = new Coordinate2D(8.0, 10.5);
      Envelope mf_env = EnvelopeBuilderEx.CreateEnvelope(mf_ll, mf_ur);
      //Reference map, create MF and add to layout
      MapProjectItem mapPrjItem = Project.Current.GetItems<MapProjectItem>()
                           .FirstOrDefault(item => item.Name.Equals("Map"));
      Map mfMap = mapPrjItem.GetMap();
      Bookmark bookmark = mfMap.GetBookmarks().FirstOrDefault(
                            b => b.Name == "Great Lakes");
      MapFrame mfElm = ElementFactory.Instance.CreateMapFrameElement(
                           layout, mf_env, mfMap, "New Map Frame");
      //Zoom to bookmark
      mfElm.SetCamera(bookmark);
    Create Map Frame 1
      //Note: QueuedTask.Run
      //Build geometry
      Coordinate2D ll = new Coordinate2D(2.0, 4.5);
      Coordinate2D ur = new Coordinate2D(4.0, 6.5);
      Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
      MapFrame mfElm = ElementFactory.Instance.CreateMapFrameElement(layout, env, map);
    Create Map Frame 2
      //Note: Must be on QueuedTask.Run(() => { ...
      //Build geometry
      Coordinate2D ll = new Coordinate2D(4.0, 2.5);
      Coordinate2D ur = new Coordinate2D(7.0, 5.5);
      layout, env.Center, map);
    Create a new spatial map series
      // This example create a new spatial map series and then applies it to the active layout. This will automatically
      // overwrite an existing map series if one is already present.
      //Note: Must be on QueuedTask.Run;
      //SpatialMapSeries constructor - required parameters
      BasicFeatureLayer indexLyr = map.FindLayers("Countries").FirstOrDefault() as BasicFeatureLayer;
      SpatialMapSeries SMS = MapSeries.CreateSpatialMapSeries(layout, mapFrame, indexLyr, "Name");
      //Set optional, non-default values
      SMS.CategoryField = "Continent";
      SMS.SortField = "Population";
      SMS.ExtentOptions = ExtentFitType.BestFit;
      SMS.MarginType = ArcGIS.Core.CIM.UnitType.PageUnits;
      SMS.MarginUnits = ArcGIS.Core.Geometry.LinearUnit.Centimeters;
      SMS.Margin = 1;
      SMS.ScaleRounding = 1000;
      layout.SetMapSeries(SMS);  //Overwrite existing map series.
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
          ArcGIS.Desktop.Layouts.Element
             ArcGIS.Desktop.Layouts.MapFrame
    Requirements
