Public NotInheritable Class Map Inherits ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase Implements ArcGIS.Desktop.Core.IMetadataInfo, IElementContainer, ILayerContainer, ILayerContainerEdit, IStandaloneTableContainer, IStandaloneTableContainerEdit, System.ComponentModel.INotifyPropertyChanged
To create a Map, you must call one of the create methods of the MapFactory class.
To open a map, use ProApp.Panes.CreateMapPaneAsync method.
You can also think of a Map as a container of layers, StandaloneTables, bookmarks etc. You need to use a MapView to interact with a map. Multiple MapViews can be opened for a Map at a given time, but there can only be one active MapView which is returned by the MapView.Active static member. Use the Map property to access the Map object associated with the MapView. The Map object has properties that operate on all layers within the map, such as spatial reference, reference scale, and so on, along with methods that manipulate the map's layers.
//This is how you get the active map
var mapToGet = MapView.Active?.Map;
//Note: Needs QueuedTask to run
MapFactory.Instance.CreateMap("The Map", ArcGIS.Core.CIM.MapType.Map, ArcGIS.Core.CIM.MapViewingMode.Map, Basemap.ProjectDefault);
//Finding the first project item with name matches with mapName
MapProjectItem? mpi = Project.Current.GetItems<MapProjectItem>()
.FirstOrDefault(m => m.Name.Equals("The Map", StringComparison.CurrentCultureIgnoreCase));
var mapFromItem = mpi?.GetMap();
if (mapFromItem != null)
//Open the map in a new map pane
//Must be called from the UI thread
await ProApp.Panes.CreateMapPaneAsync(map);
//Assume we get the selected webmap from the Project pane's Portal tab
if (Project.Current.SelectedItems.Count > 0)
if (MapFactory.Instance.CanCreateMapFrom(Project.Current.SelectedItems[0]))
map = MapFactory.Instance.CreateMapFromItem(Project.Current.SelectedItems[0]);
System.Object
ArcGIS.Desktop.Mapping.Map
