ArcGIS.Desktop.Mapping Namespace / MapView Class / Active Property
Example
    Active Property (MapView)
    Gets the active map view. Returns null if there is no active map view.
    Syntax
    public static MapView Active {get;}
    Public Shared ReadOnly Property Active As MapView
    Example
    Lookup Symbol
      //feature layer from the active map
      var lookupMapView = MapView.Active;
      var featureLayerLookUp = lookupMapView.Map.GetLayersAsFlattenedList()
                              .OfType<FeatureLayer>()
                              .FirstOrDefault();
      await QueuedTask.Run(() =>
        //Get the selection
        var selection = featureLayerLookUp.GetSelection();
        //Get the first Object ID
        var firstOID = selection.GetObjectIDs().FirstOrDefault();
        //Determine whether the layer's renderer type supports symbol lookup.
        if (featureLayerLookUp.CanLookupSymbol())
          //Looks up the symbol for the corresponding feature identified by the object id.
          var lookupSymbol = featureLayerLookUp.LookupSymbol(firstOID, lookupMapView);
          var jSon = lookupSymbol.ToJson(); //Create a JSON encoding of the symbol
                                            //Do something with symbol
    Get the active map
      //This is how you get the active map
      var mapToGet = MapView.Active?.Map;
    Change the Map name and caption of the active pane
      var activeMap = MapView.Active?.Map;
      await QueuedTask.Run(() => activeMap?.SetName("Test"));
      ProApp.Panes.ActivePane.Caption = "Caption";
    Clip Map to the provided clip polygon
      var mapToClip = MapView.Active.Map;
        //A layer to use for the clip extent
        var lyrOfInterest = mapToClip.GetLayersAsFlattenedList().OfType<FeatureLayer>().Where(l => l.Name == "TestPoly").FirstOrDefault();
        //Get the polygon to use to clip the map
        var extent = lyrOfInterest.QueryExtent();
        var polygonForClipping = PolygonBuilderEx.CreatePolygon(extent);
        //Clip the map using the layer's extent
        mapToClip.SetClipGeometry(polygonForClipping,
              SymbolFactory.Instance.ConstructLineSymbol(
              SymbolFactory.Instance.ConstructStroke(
                ColorFactory.Instance.BlueRGB, 2.0, SimpleLineStyle.Dash)));
    Clear the current map clip geometry
      var mapWithClip = MapView.Active.Map;
      //Clear the Map clip.
      //If no clipping is set then this is a no-op.
      mapWithClip.ClearClipGeometry();
    Get the map clipping geometry
        //If clipping is set to ArcGIS.Core.CIM.ClippingMode.None or ArcGIS.Core.CIM.ClippingMode.MapSeries null is returned
        //If clipping is set to ArcGIS.Core.CIM.ClippingMode.MapExtent the ArcGIS.Core.CIM.CIMMap.CustomFullExtent is returned.
        //Otherwise, if clipping is set to ArcGIS.Core.CIM.ClippingMode.CustomShape the custom clip polygon is returned.
        var poly = mapWithClip.GetClipGeometry();
        //You can use the polygon returned
        //For example: We make a polygon graphic element and add it to a Graphics Layer.
        var gl = mapWithClip.GetLayersAsFlattenedList().OfType<GraphicsLayer>().FirstOrDefault();
        if (gl == null)
          return;
        var polygonSymbol = SymbolFactory.Instance.ConstructPolygonSymbol(CIMColor.CreateRGBColor(255, 255, 0));
        var cimGraphicElement = new CIMPolygonGraphic
          Polygon = poly,
          Symbol = polygonSymbol.MakeSymbolReference()
        gl.AddElement(cimGraphicElement);
    Get the Grid Options for a Map
      var gridOptionsMapView = MapView.Active;
      if (gridOptionsMapView == null)
        return;
        //Does the 'map' currently have any options?
        var hasOptions = GridOptionsEnvironment.Instance.HasGridOptions(map);
        //If grid options have not been set for the map, then default grid options are added
        //for the map otherwise the existing gridoptions are returned.
        //NOTE: Grid options are returned by value meaning a copy is always returned. Any changes made to the
        //grid options need to be -set- back on the map using SetGridOptions for the changes to persist.
        var gridOptions = GridOptionsEnvironment.Instance.GetGridOptions(
                                           gridOptionsMapView.Map);
        //Only return grid options if grid options have previously been set:
        var gridOptions2 = GridOptionsEnvironment.Instance.GetGridOptions(
                                           gridOptionsMapView.Map, false);
    Export Map Raster Tile Cache Content
      //Does the map have any exportable raster content?
      var canExport = GenerateOfflineMap.Instance.GetCanExportRasterTileCache(map);
      var rasterTileExtent = MapView.Active.Extent;
      if (canExport)
        //Check the available LOD scale ranges
        var scales = GenerateOfflineMap.Instance.GetExportRasterTileCacheScales(map, rasterTileExtent);
        //Pick the desired LOD scale
        var max_scale = scales[scales.Count() / 2];
        //Configure the export parameters
        var export_params = new ExportTileCacheParams()
          Extent = rasterTileExtent,//Use same extent as was used to retrieve scales
          MaximumUserDefinedScale = max_scale
          //DestinationFolder = .... (optional)
        //If DestinationFolder is not set, output defaults to project
        //offline maps location set in the project properties. If that is
        //not set, output defaults to the current project folder location.
        //Do the export. Depending on the MaximumUserDefinedScale and the
        //area of the extent requested, this can take minutes for tile packages
        //over 1 GB or less if your network speed is slow...
        GenerateOfflineMap.Instance.ExportRasterTileCache(map, export_params);
    Export Map Vector Tile Cache Content
      var mapVectorTileExtent = MapView.Active.Extent;
      //Does the map have any exportable vector tile content?
      var canExport = GenerateOfflineMap.Instance.GetCanExportVectorTileCache(map);
      if (canExport)
        var scales = GenerateOfflineMap.Instance.GetExportVectorTileCacheScales(map, mapVectorTileExtent);
          Extent = mapVectorTileExtent,//Use same extent as was used to retrieve scales
          MaximumUserDefinedScale = max_scale,
          DestinationFolder = @"C:\Data\Offline"
        GenerateOfflineMap.Instance.ExportVectorTileCache(map, export_params);
    Apply Symbology to a layer from a Layer file
      IEnumerable<FeatureLayer> featureLayers = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>()
        .Where(l => l.ShapeType == esriGeometryType.esriGeometryPoint);
      var layerFile = @"C:\Data\SDK\UniqueValuePointLayer.lyrx";
      foreach (var featureLayerToSymbolize in featureLayers)
        //Get the Layer Document from the lyrx file
        var lyrDocFromLyrxFile = new LayerDocument(layerFile);
        var cimLyrDoc = lyrDocFromLyrxFile.GetCIMLayerDocument();
        //Get the renderer from the layer file
        var rendererFromLayerFile = ((CIMFeatureLayer)cimLyrDoc.LayerDefinitions[0]).Renderer as CIMUniqueValueRenderer;
        //Apply the renderer to the feature layer
        //Note: If working with a raster layer, use the SetColorizer method.
        featureLayerToSymbolize?.SetRenderer(rendererFromLayerFile);
    Get a layer of a certain geometry type
      //Get an existing Layer. This layer has a symbol you want to use in a new layer.
      var lyr = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>()
              .Where(l => l.ShapeType == esriGeometryType.esriGeometryPoint).FirstOrDefault();
    Find a layer
      //Finds layers by name and returns a read only list of Layers
      IReadOnlyList<Layer> layers = map.FindLayers("cities", true);
      //Finds a layer using a URI.
      //The Layer URI you pass in helps you search for a specific layer in a map
      var lyrFindLayer = MapView.Active.Map.FindLayer("CIMPATH=map/u_s__states__generalized_.xml");
      //This returns a collection of layers of the "name" specified. You can use any Linq expression to query the collection.
      var lyrExists = MapView.Active.Map.GetLayersAsFlattenedList()
                         .OfType<FeatureLayer>().Any(f => f.Name == "U.S. States (Generalized)");
    Create a Lyrx file from mulltiple mapMembers
      // get the layers selected in the TOC
      var selectedLayers = MapView.Active.GetSelectedLayers();
      // get the standalonetables elected in the TOC
      var selectedTables = MapView.Active.GetSelectedStandaloneTables();
      var selectedMMs = new List<MapMember>(selectedLayers);
      selectedMMs.AddRange(selectedTables);
      // create the LayerDocument
      LayerDocument layerDocument = new LayerDocument(selectedMMs);
      await QueuedTask.Run(() => layerDocument.Save(@"c:\Data\MyLayerDocument.lyrx"));
    Count the features selected on a layer
      var lyr = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault();
      var noFeaturesSelected = lyr.SelectionCount;
    Retrieve a table from its container
      var container = MapView.Active.Map;
      //the map standalone table collection
      var table = container.GetStandaloneTablesAsFlattenedList()
                              .FirstOrDefault(tbl => tbl.Name == "EarthquakeDamage");
      //or from a group layer
      var grp_layer = MapView.Active.Map.FindLayers("GroupLayer1").First() as GroupLayer;
      var table2 = grp_layer.FindStandaloneTables("EarthquakeDamage").First();
      //or         grp_layer.GetStandaloneTablesAsFlattenedList().First()
      //or         grp_layer.StandaloneTables.Where(...).First(), etc.
      //show the table in a table view
      //use FrameworkApplication.Current.Dispatcher.BeginInvoke if not on the UI thread
      FrameworkApplication.Panes.OpenTablePane(table2);
    Move a Standalone table
      //get the first group layer that has at least one table
      var grp_layer = MapView.Active.Map.GetLayersAsFlattenedList()
        .OfType<GroupLayer>().First(g => g.StandaloneTables.Count > 0);
      grp_layer.MoveStandaloneTable(grp_layer.StandaloneTables.First(), -1);
      //move the last table in the map standalone tables to a group
      //layer and place it at position 3. If 3 is invalid, the table
      //will be placed at the bottom of the target container
      //assumes the map has at least one standalone table...
      var table = map.StandaloneTables.Last();
      map.MoveStandaloneTable(table, grp_layer, 3);
      //move a table from a group layer to the map standalone tables
      //collection - assumes a table called 'Earthquakes' exists
      var table2 = grp_layer.FindStandaloneTables("Earthquakes").First();
      //move to the map container
      map.MoveStandaloneTable(table2, 0);//will be placed at the top
    Check SelectionSet Equality
      // get map selection
      var mapSelSet = MapView.Active.Map.GetSelection();
      // create a selectionSet
      var selDict = new Dictionary<MapMember, List<long>>();
      selDict.Add(featureLayer, new List<long> { 1506, 2696, 2246, 1647, 948 });
      var layerSelSet = ArcGIS.Desktop.Mapping.SelectionSet.FromDictionary(selDict);
      // test for equality - use Equals method
      var isEquals = mapSelSet.Equals(layerSelSet);
      // test for equality - use operators
      var equals = mapSelSet == layerSelSet;
      var notEquals = mapSelSet != layerSelSet;
    Get Elevation profile from the default ground surface
      // get the elevation profile for a polyline / set of polylines
      Polyline polyline = PolylineBuilderEx.CreatePolyline();
      MapPoint mapPoint = MapPointBuilderEx.CreateMapPoint(34, -118, SpatialReferences.WGS84);
      List<MapPoint> mapPoints = new List<MapPoint> { mapPoint };
      var result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync([polyline]);
      if (result.Status == SurfaceZsResultStatus.Ok)
        var polylineZ = result.Polyline;
        // process the polylineZ
        // get the elevation profile for a set of points
        result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(mapPoints);
    Get Elevation profile from a specific surface
      // find a specific elevation surface layer
      var eleLayer = MapView.Active.Map.GetElevationSurfaceLayers().FirstOrDefault(l => l.Name == "TIN");
      // use the specific elevation surface layer
      var zResult = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync([polyline], eleLayer);
      if (zResult.Status == SurfaceZsResultStatus.Ok)
        var polylineZ = zResult.Polyline;
      zResult = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(mapPoints, eleLayer);
    Interpolate a line between two points and calculate the elevation profile
      int numPoints = 20;//Or any number of points you want to interpolate
                         // use a specific elevation surface
      // use the default ground elevation surface
      MapPoint startPt = MapPointBuilderEx.CreateMapPoint(-130, 20, SpatialReferences.WGS84);
      MapPoint endPt = MapPointBuilderEx.CreateMapPoint(-100, 50, SpatialReferences.WGS84);
      var result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(startPt, endPt, numPoints);
      result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(startPt, endPt, numPoints, eleLayer);
    Show Elevation profile graph with the default ground surface
      if (!MapView.Active.CanShowElevationProfileGraph())
        return;
      // show the elevation profile for a polyline
      // use the default ground surface layer
      MapView.Active.ShowElevationProfileGraph([polyline]);
      // show the elevation profile for a set of points
      //Some points
      MapView.Active.ShowElevationProfileGraph(mapPoints);
    Show Elevation profile graph with a specific surface
        return;
      // set up the parameters
      var profileParams = new ElevationProfileParameters();
      profileParams.SurfaceLayer = eleLayer;
      profileParams.Densify = true;
      // show the elevation profile for a polyline using the params
      //Any line
      MapView.Active.ShowElevationProfileGraph([polyline], profileParams);
      // show the elevation profile for a set of points using the params
      //Some points
      MapView.Active.ShowElevationProfileGraph(mapPoints, profileParams);
    Show Elevation profile graph between two points
      int numPoints = 20;
        return;
      MapView.Active.ShowElevationProfileGraph(startPt, endPt, numPoints);
      var tinLayer = MapView.Active.Map.GetElevationSurfaceLayers().FirstOrDefault(l => l.Name == "TIN");
      // set up the params
      var elevProfileParams = new ElevationProfileParameters();
      elevProfileParams.SurfaceLayer = tinLayer;
      elevProfileParams.Densify = false;
      // show the elevation profile using the params
      MapView.Active.ShowElevationProfileGraph(startPt, endPt, numPoints, elevProfileParams);
    Show Elevation profile graph using an ElevationProfileResult
      var elevProfileResult = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(startPt, endPt, 10);
      if (elevProfileResult.Status != SurfaceZsResultStatus.Ok)
        return;
        return;
      // show the elevation profile using the result
      MapView.Active.ShowElevationProfileGraph(elevProfileResult);
    Access the ElevationProfileGraph when added
      // subscribe to the Added, Removed events for the elevation profile graph
      mapView.ElevationProfileGraphAdded += Mv_ElevationProfileGraphAdded;
      mapView.ElevationProfileGraphRemoved += Mv_ElevationProfileGraphRemoved;
      //Handles the event triggered when an elevation profile graph is removed.
      void Mv_ElevationProfileGraphRemoved(object sender, EventArgs e)
        //TODO: handle the removal of the elevation profile graph
      //Handles the event triggered when an elevation profile graph is added to the active map view.
      void Mv_ElevationProfileGraphAdded(object sender, EventArgs e)
        // get the elevation profile graph from the view
        // this will be non-null since we are in a ElevationProfileGraphAdded handler
        var mv = MapView.Active;
        var graph = mv.GetElevationProfileGraph();
        // subscribe to the ContentLoaded event
        graph.ContentLoaded += Graph_ContentLoaded;
      // Handles the event triggered when the elevation profile graph content is loaded.
      void Graph_ContentLoaded(object sender, EventArgs e)
        var graph = sender as ArcGIS.Desktop.Mapping.ElevationProfileGraph;
        // get the elevation profile geometry
        var polyline = graph.Geometry;
        // get the elevation profile statistics
        var stats = graph.ElevationProfileStatistics;
      var elevProfileGraph = MapView.Active.GetElevationProfileGraph();
      // Elevation profile graph will be null if no profile graph is displayed
      if (elevProfileGraph == null)
        return;
      // get the elevation profile geometry and stats
      var polyline = elevProfileGraph.Geometry;
      var stats = elevProfileGraph.ElevationProfileStatistics;
      // reverse the graph
      elevProfileGraph.IsReversed = !elevProfileGraph.IsReversed;
      // collapse the graph
      elevProfileGraph.IsExpanded = false;
    Export Elevation Profile Graph
        return;
      if (elevProfileGraph.CanExport)
        elevProfileGraph.ExportToImage("c:\\temp\\myprofileImage.png");
        elevProfileGraph.ExportToCSV("c:\\temp\\myprofile.csv");
    Get the Mask Geometry for a Feature
      if (featureLayer == null)
        return;
        using (var table = featureLayer.GetTable())
          using (var rc = table.Search())
            //get the first feature...
            //...assuming at least one feature gets retrieved
            rc.MoveNext();
            var oid = rc.Current.GetObjectID();
            //Use DrawingOutlineType.BoundingEnvelope to retrieve a generalized
            //mask geometry or "Box". The mask will be in the same SpatRef as the map
            var mask_geom = featureLayer.GetDrawingOutline(oid, mv, DrawingOutlineType.Exact);
            //TODO - use the mask geometry...
    Get the Active Map TOC content type
      //Get the current active TOC content type for the map view
      var mapTOCContentType = MapView.Active.CurrentMapTOCContent;
    Set the Active Map TOC content type
      var mapTOCContentType = (int)MapView.Active.CurrentMapTOCContent;
      //increment to the next tab whatever it is
      mapTOCContentType++;
      //Can we set this type on the TOC?
      if (MapView.Active.CanSetMapTOCContent((MapTOCContentType)mapTOCContentType))
        //Set it - must be on the UI! - No QueuedTask
        MapView.Active.SetMapTOCContentAsync((MapTOCContentType)mapTOCContentType);
      else
        mapTOCContentType = (int)MapTOCContentType.DrawingOrder;
    Export the contents of a scene to an exchange format such as glTF and STL.
      // Validate the current active view. Only a local scene can be exported.
      bool CanExportScene3DObjects = MapView.Active?.ViewingMode == MapViewingMode.SceneLocal;
      if (CanExportScene3DObjects)
        // Create a scene content export format, export the scene context as a glTF file
        var exportFormat = new ExportSceneContentsFormat()
          Extent = mapView.Extent, // sets Extent property
          FolderPath = @"C:\Temp", // sets FolderPath property
                                   //sets FileName property.The export format is determined by the output file extension (e.g.,.stl, .gltf)
          FileName = "my-3d-objects.gltf",
          IsSingleFileOutput = true, // sets whether to export to one single file
          SaveTextures = true //sets whether to save textures
        // Export the scene content as 3D objects
        mapView.ExportScene3DObjects(exportFormat);
    Zoom to ObjectIDs
      using var rowCursor = featureLayer.Search();
      var objectIds = new List<long>();
      while (rowCursor.MoveNext())
        using var feature = rowCursor.Current as Feature;
        objectIds.Add(feature.GetObjectID());
      if (objectIds.Count > 0)
        MapView.Active.ZoomTo(featureLayer, objectIds, TimeSpan.FromSeconds(2));
    MapView Overlay Control
      //Create a Progress Bar user control
      System.Windows.Controls.ProgressBar progressBarControl = new()
        //Configure the progress bar
        Minimum = 0,
        Maximum = 100,
        IsIndeterminate = true,
        Width = 300,
        Value = 10,
        Height = 25,
        Visibility = System.Windows.Visibility.Visible
      //Create a MapViewOverlayControl.
      var mapViewOverlayControl = new MapViewOverlayControl(progressBarControl, true, true, true, OverlayControlRelativePosition.BottomCenter, .5, .8);
      //Add to the active map
      MapView.Active.AddOverlayControl(mapViewOverlayControl);
        //Wait 3 seconds to remove the progress bar from the map.
        Thread.Sleep(3000);
      //Remove from active map
      MapView.Active.RemoveOverlayControl(mapViewOverlayControl);
    Select a layer and open its layer properties page
      // select it in the TOC
      List<Layer> layersToSelect = [featureLayer];
      MapView.Active.SelectLayers(layersToSelect);
      // now execute the layer properties command
      var wrapper = FrameworkApplication.GetPlugInWrapper("esri_mapping_selectedLayerPropertiesButton");
      var command = wrapper as ICommand;
      if (command == null)
        // the command is not found, leave
      // execute the command
      if (command.CanExecute(null))
        command.Execute(null);
    Display Table pane for Map Member
      mapMember = MapView.Active.Map.GetLayersAsFlattenedList().OfType<MapMember>().FirstOrDefault();
      //Gets or creates the CIMMapTableView for a MapMember.
      var mapTableView = FrameworkApplication.Panes.GetMapTableView(mapMember);
      //Configure the table view
      mapTableView.DisplaySubtypeDomainDescriptions = false;
      mapTableView.SelectionMode = false;
      mapTableView.ShowOnlyContingentValueFields = true;
      mapTableView.HighlightInvalidContingentValueFields = true;
      //Open the table pane using the configured tableView. If a table pane is already open it will be activated.
      //You must be on the UI thread to call this function.
      var tablePane = FrameworkApplication.Panes.OpenTablePane(mapTableView);
    Disable time in the map.
      MapView.Active.Time.Start = null;
      MapView.Active.Time.End = null;
    Show A Dynamic Pop-up
    public static void ShowDynamicPopup(MapMember mapMember, List<long> objectIDs)
      MapView mapView = MapView.Active;
      if (mapView == null)
        return;
      //Create popup whose content is created the first time the item is requested.
      var popups = new List<PopupContent>();
      foreach (var id in objectIDs)
        popups.Add(new DynamicPopupContent(mapMember, id));
      mapView.ShowCustomPopup(popups);
    internal class DynamicPopupContent : PopupContent
      public DynamicPopupContent(MapMember mapMember, long objectID)
        MapMember = mapMember;
        IDString = objectID.ToString();
        IsDynamicContent = true;
      //Called when the pop-up is loaded in the window.
      protected override Task<string> OnCreateHtmlContent()
        return QueuedTask.Run(() => string.Format("<b>Map Member: {0}, ID: {1}</b>", MapMember, IDString));
    EsriHttpClient: Get a Service Layer and Add it to Pro
      UriBuilder searchURL = new UriBuilder(ArcGISPortalManager.Current.GetActivePortal().PortalUri)
        Path = "sharing/rest/search"
      string layers = "(type:\"Map Service\" OR type:\"Image Service\" OR type:\"Feature Service\" OR type:\"WMS\" OR type:\"KML\")";
      //any public layer content
      searchURL.Query = string.Format("q={0}&f=json", layers);
      EsriHttpClient httpClient = new EsriHttpClient();
      var searchResponse = httpClient.Get(searchURL.Uri.ToString());
      dynamic resultItems = JObject.Parse(await searchResponse.Content.ReadAsStringAsync());
      long numberOfTotalItems = resultItems.total.Value;
      if (numberOfTotalItems == 0)
        return;
      List<dynamic> resultItemList = new List<dynamic>();
      resultItemList.AddRange(resultItems.results);
      //get the first result
      dynamic item = resultItemList[0];
      string itemID = item.id;
      Item currentItem = ItemFactory.Instance.Create(itemID, ItemFactory.ItemType.PortalItem);
      var mapView = MapView.Active;
        return;
        //Create a LayerCreationParam
        var layerParam = new LayerCreationParams(currentItem);
        // if we have an item that can be turned into a layer
        // add it to the map
        if (LayerFactory.Instance.CanCreateLayerFrom(currentItem))
          LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParam, mapView.Map);
    Get the active map's labeling engine - Maplex or Standard labeling engine
      var map = MapView.Active?.Map;
      if (map == null)
        return;
        //Get the active map's definition - CIMMap.
        var cimMap = map.GetDefinition();
        //Get the labeling engine from the map definition
        CIMGeneralPlacementProperties labelEngine = cimMap.GeneralPlacementProperties;
    Change the active map's labeling engine from Standard to Maplex or vice versa
      if (map == null)
        return;
        var cimGeneralPlacement = cimMap.GeneralPlacementProperties;
        if (cimGeneralPlacement is CIMMaplexGeneralPlacementProperties)
          //Current labeling engine is Maplex labeling engine
          //Create a new standard label engine properties
          var cimStandardPlacementProperties = new CIMStandardGeneralPlacementProperties();
          //Set the CIMMap's GeneralPlacementProperties to the new label engine
          cimMap.GeneralPlacementProperties = cimStandardPlacementProperties;
        else
          //Current labeling engine is Standard labeling engine
          //Create a new Maplex label engine properties
          var cimMaplexGeneralPlacementProperties = new CIMMaplexGeneralPlacementProperties();
          cimMap.GeneralPlacementProperties = cimMaplexGeneralPlacementProperties;
        //Set the map's definition
        map.SetDefinition(cimMap);
    Modify the Placement/Position of labels - Line geometry
      if (map == null)
        return;
        //Get the layer's definition
        var lyrDefn = featureLayer.GetDefinition() as CIMFeatureLayer;
        //Get the label classes - we need the first one
        var listLabelClasses = lyrDefn.LabelClasses.ToList();
        var theLabelClass = listLabelClasses.FirstOrDefault();
        //Modify label Placement
        //Check if the label engine is Maplex or standard.
            map.GetDefinition().GeneralPlacementProperties;
        if (labelEngine is CIMStandardGeneralPlacementProperties)
          var lineLablePosition = new CIMStandardLineLabelPosition
            Perpendicular = true,
            Parallel = false,
            ProduceCurvedLabels = false,
            Horizontal = false,
            OnTop = true
          theLabelClass.StandardLabelPlacementProperties.LineLabelPosition =
              lineLablePosition;
        else //Current labeling engine is Maplex labeling engine
          theLabelClass.MaplexLabelPlacementProperties.LinePlacementMethod =
                        MaplexLinePlacementMethod.CenteredPerpendicularOnLine;
          theLabelClass.MaplexLabelPlacementProperties.LineFeatureType =
                        MaplexLineFeatureType.General;
        //theLabelClass.MaplexLabelPlacementProperties.LinePlacementMethod = MaplexLinePlacementMethod.CenteredPerpendicularOnLine;
        lyrDefn.LabelClasses = listLabelClasses.ToArray(); //Set the labelClasses back
        featureLayer.SetDefinition(lyrDefn); //set the layer's definition
    Modify the Placement/Position of labels - Polygon geometry
      if (map == null)
        return;
        CIMGeneralPlacementProperties labelEngine = map.GetDefinition().GeneralPlacementProperties;
          //Current labeling engine is Standard Labeling engine
          theLabelClass.StandardLabelPlacementProperties.PolygonPlacementMethod =
                   StandardPolygonPlacementMethod.AlwaysHorizontal;
          theLabelClass.StandardLabelPlacementProperties.PlaceOnlyInsidePolygon = true;
        else
          theLabelClass.MaplexLabelPlacementProperties.PolygonFeatureType =
                                   MaplexPolygonFeatureType.LandParcel;
          theLabelClass.MaplexLabelPlacementProperties.AvoidPolygonHoles = true;
          theLabelClass.MaplexLabelPlacementProperties.PolygonPlacementMethod =
                              MaplexPolygonPlacementMethod.HorizontalInPolygon;
          theLabelClass.MaplexLabelPlacementProperties.CanPlaceLabelOutsidePolygon = true;
                                             //set the label's visiblity
        featureLayer.SetLabelVisibility(true);
    Modify Orientation of a label using the MaplexEngine - Points and Polygon geometry
      if (map == null)
        return;
          return;
        //Modify label Orientation
        theLabelClass.MaplexLabelPlacementProperties.GraticuleAlignment = true;
        theLabelClass.MaplexLabelPlacementProperties.GraticuleAlignmentType = MaplexGraticuleAlignmentType.Curved;
    Modify Orientation of a label using the MaplexEngine - Line geometry
      if (map == null)
        return;
          return;
        theLabelClass.MaplexLabelPlacementProperties.AlignLabelToLineDirection = true;
    Modify label Rotation - Point geometry
      if (map == null)
        return;
          return;
        //Modify label Rotation
        CIMMaplexRotationProperties rotationProperties = new CIMMaplexRotationProperties
          Enable = true, //Enable rotation
          RotationField = "ELEVATION", //Field that is used to define rotation angle
          AdditionalAngle = 15, //Additional rotation
          RotationType = MaplexLabelRotationType.Arithmetic,
          AlignmentType = MaplexRotationAlignmentType.Perpendicular,
          AlignLabelToAngle = true
        theLabelClass.MaplexLabelPlacementProperties.RotationProperties = rotationProperties;
    Spread labels across Polygon geometry
      if (map == null)
        return;
          return;
        //Spread Labels (words and characters to fill feature)
        // Spread words to fill feature
        theLabelClass.MaplexLabelPlacementProperties.SpreadWords = true;
        //Spread Characters to a fixed limit of 50%
        theLabelClass.MaplexLabelPlacementProperties.SpreadCharacters = true;
        theLabelClass.MaplexLabelPlacementProperties.MaximumCharacterSpacing = 50.0;
    Modify label's Leader Line Anchor point properties - Polygon geometry
      if (map == null)
        return;
          return;
        //If TextSymbol is a call-out the leader line anchor point can be modified
        theLabelClass.MaplexLabelPlacementProperties.PolygonAnchorPointType = MaplexAnchorPointType.Perimeter;
        lyrDefn.LabelClasses = [.. listLabelClasses]; //Set the labelClasses back
    Create a Scene Layer
      if (map == null)
        return;
        //Create with initial visibility set to false. Add to current scene
        var createparams = new LayerCreationParams(new Uri(sceneLayerUrl, UriKind.Absolute))
          IsVisible = false
        //cast to specific type of scene layer being created - in this case FeatureSceneLayer
        var sceneLayer = LayerFactory.Instance.CreateLayer<Layer>(
                 createparams, map) as FeatureSceneLayer;
        //or...specify the cast directly
        var sceneLayer2 = LayerFactory.Instance.CreateLayer<FeatureSceneLayer>(
                 createparams, map);
        //ditto for BuildingSceneLayer, PointCloudSceneLayer, IntegratedMeshSceneLayer
    Get BuildingDisciplineSceneLayer Discipline
      var bsl_discipline = MapView.Active.Map.GetLayersAsFlattenedList().OfType<BuildingDisciplineSceneLayer>().FirstOrDefault(l => l.Name == "Architectural");
      var disciplineName = bsl_discipline.GetDiscipline();
    Enumerate the Discipline Layers from a Building SceneLayer
      var bldgLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<BuildingSceneLayer>().First();
      var disciplines = new Dictionary<string, BuildingDisciplineSceneLayer>();
      //A Building layer has two children - Overview and FullModel
      //Overview is a FeatureSceneLayer
      //Full Model is a BuildingDisciplineSceneLayer that contains the disciplines
      var fullModel = bldgLayer.FindLayers("Full Model").First()
                                     as BuildingDisciplineSceneLayer;
      //collect information on the disciplines
      var name = fullModel.Name;
      var discipline = fullModel.GetDiscipline();
      //etc
      //TODO - use collected information
      disciplines.Add(discipline, fullModel);
      //Discipline layers are composite layers too
      foreach (var childDiscipline in fullModel.Layers
                          .OfType<BuildingDisciplineSceneLayer>())
        //Discipline layers can also contain FeatureSceneLayers that render the
        //individual full model contents
        var content_names = string.Join(", ", childDiscipline.Layers
             .OfType<FeatureSceneLayer>().Select(fl => fl.Name));
        // Recursively call this "function" to go deeper
    Name of BuildingSceneLayer
      bsl = MapView.Active.Map.GetLayersAsFlattenedList()
            .OfType<BuildingSceneLayer>().FirstOrDefault();
      var scenelayerName = bsl.Name;
    Determine if a FeatureSceneLayer supports editing
      featSceneLayer = MapView.Active.Map.GetLayersAsFlattenedList()
                         .OfType<FeatureSceneLayer>().FirstOrDefault();
      if (!featSceneLayer.HasAssociatedFeatureService ||
          !featSceneLayer.IsEditable)
        //not supported - exit the function
      //TODO continue editing here...
    Name of FeatureSceneLayer
      var scenelayerName = featSceneLayer?.Name;
    Select features via the MapView
      //assume the geometry used in SelectFeaturesEx() is coming from a
      //map tool...
      //SketchType = SketchGeometryType.Rectangle;
      //SketchOutputMode = SketchOutputMode.Screen;
        return;
        var result = mapView.SelectFeaturesEx(geometry);
        //Get scene layers with selections
        var scene_layers = result.ToDictionary<FeatureSceneLayer>();
        foreach (var kvp in scene_layers)
          var scene_layer = kvp.Key as FeatureSceneLayer;
          var sel_oids = kvp.Value;
          //If there are attributes then get them
          if (scene_layer.HasAssociatedFeatureService)
            var insp = new Inspector();
            foreach (var objectid in sel_oids)
              insp.Load(scene_layer, objectid);
              //TODO something with retrieved attributes
    Use MapView Selection SelectFeaturesEx or GetFeaturesEx
      var sname = featSceneLayer.Name;
        return;
        //Select all features within the current map view
        var sz = mapView.GetViewSize();
        var c_ll = new Coordinate2D(0, 0);
        var c_ur = new Coordinate2D(sz.Width, sz.Height);
        //Use screen coordinates for 3D selection on MapView
        var env = EnvelopeBuilderEx.CreateEnvelope(c_ll, c_ur);
        //HasAssociatedFeatureService does not matter for SelectFeaturesEx
        //or GetFeaturesEx
        var result = mapView.SelectFeaturesEx(env);
        //var result = mapView.GetFeaturesEx(env);
        //The list of object ids from SelectFeaturesEx
        var oids1 = result.ToDictionary().Where(kvp => kvp.Key.Name == sname).First().Value;
        //TODO - use the object ids
        mapView.Map.ClearSelection();
    Use Select or Search with a Spatial Query
        return;
        if (!featSceneLayer.HasAssociatedFeatureService)
          return;//no search or select
        var map_pt1 = mapView.ClientToMap(new System.Windows.Point(0, sz.Height));
        var map_pt2 = mapView.ClientToMap(new System.Windows.Point(sz.Width, 0));
        //Convert to an envelope
        var temp_env = EnvelopeBuilderEx.CreateEnvelope(map_pt1, map_pt2, mapView.Map.SpatialReference);
        //Project if needed to the layer spatial ref
        SpatialReference sr = null;
        using (var fc = featSceneLayer.GetFeatureClass())
        using (var fdef = fc.GetDefinition())
          sr = fdef.GetSpatialReference();
        var env = GeometryEngine.Instance.Project(temp_env, sr) as Envelope;
        //Set up a query filter
        var sf = new SpatialQueryFilter()
          FilterGeometry = env,
          SpatialRelationship = SpatialRelationship.Intersects,
          SubFields = "*"
        //Select against the feature service
        var select = featSceneLayer.Select(sf);
        if (select.GetCount() > 0)
          //enumerate over the selected features
          using (var rc = select.Search())
            while (rc.MoveNext())
              using (var feature = rc.Current as Feature)
                oid = feature.GetObjectID();
                //etc.
    Find all Stream Layers that are Track Aware
      var trackAwareLayers = MapView.Active.Map.GetLayersAsFlattenedList()
                                 .OfType<StreamLayer>().Where(sl => sl.IsTrackAware)?.ToList();
    Check if a Voxel Layer can be created
      //Map must be a local scene
      bool canCreateVoxel = (MapView.Active.ViewingMode == MapViewingMode.SceneLocal);
      if (canCreateVoxel)
        //TODO - use the voxel api methods
    Get a Voxel Layer from the TOC
      //Get selected layer if a voxel layer is selected
      voxelLayer = MapView.Active.GetSelectedLayers().OfType<VoxelLayer>().FirstOrDefault();
      if (voxelLayer == null)
        //just get the first voxel layer in the TOC
        voxelLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<VoxelLayer>().FirstOrDefault();
          return;
    Get/Set Selected Voxel Assets from the TOC
      var surfaces = MapView.Active.GetSelectedIsosurfaces();
      //set selected w/ MapView.Active.SelectVoxelIsosurface(isoSurface)
      var slices = MapView.Active.GetSelectedSlices();
      //set selected w/ MapView.Active.SelectVoxelSlice(slice)
      var sections = MapView.Active.GetSelectedSections();
      //set selected w/ MapView.Active.SelectVoxelSection(section)
      var locked_sections = MapView.Active.GetSelectedLockedSections();
      //set selected w/ MapView.Active.SelectVoxelLockedSection(locked_section)
    Subscribe for Changes to a Voxel Layer
      MapMemberPropertiesChangedEvent.Subscribe((args) =>
        var voxel = args.MapMembers.OfType<VoxelLayer>().FirstOrDefault();
        if (voxel == null)
          return;
        //Anything changed on a voxel layer?
        if (args.EventHints.Any(hint => hint == MapMemberEventHint.VoxelSelectedVariable))
          //Voxel variable profile selection changed
          var changed_variable_name = voxel.SelectedVariableProfile.Variable;
          //TODO respond to change, use QueuedTask if needed
        else if (args.EventHints.Any(hint => hint == MapMemberEventHint.Renderer))
          //This can fire when a renderer becomes ready on a new layer; the selected variable profile
          //is changed; visualization is changed, etc.
          var renderer = voxel.SelectedVariableProfile.Renderer;
      VoxelAssetChangedEvent.Subscribe((args) =>
        //An asset changed on a voxel layer
        System.Diagnostics.Debug.WriteLine("");
        System.Diagnostics.Debug.WriteLine("VoxelAssetChangedEvent");
        System.Diagnostics.Debug.WriteLine($" AssetType: {args.AssetType}, ChangeType: {args.ChangeType}");
        if (args.ChangeType == VoxelAssetEventArgs.VoxelAssetChangeType.Remove)
          return;
        //Get "what"changed - add or update
        //eg IsoSurface
        VoxelLayer voxelLayer = null;
        if (args.AssetType == VoxelAssetEventArgs.VoxelAssetType.Isosurface)
          var surface = MapView.Active.GetSelectedIsosurfaces().FirstOrDefault();
          //there will only be one selected...
          if (surface != null)
            voxelLayer = surface.Layer;
        //Repeat for Slices, Sections, LockedSections...
        //GetSelectedSlices(), GetSelectedSections(), GetSelectedLockedSections();
    Get Selected Slice in TOC
        var slice = mapView?.GetSelectedSlices()?.FirstOrDefault();
        if (slice != null)
          //Do something with the slice
    Get Voxel Layer for the Selected Slice in TOC
        voxelLayer = null;
        if (slice != null)
          voxelLayer = slice.Layer;
          //TODO - use the layer
    Get the Selected Section in TOC
      var section = MapView.Active?.GetSelectedSections()?.FirstOrDefault();
      if (section != null)
        //Do something with the section
    Get Voxel Layer for the Selected Section in TOC
      voxelLayer = null;
        voxelLayer = section.Layer;
    Get Selected Locked Section in TOC
      var locked_section = MapView.Active?.GetSelectedLockedSections()?.FirstOrDefault();
      if (locked_section != null)
        // Use the locked section
    Get Voxel Layer for the Selected Locked Section in TOC
        voxelLayer = locked_section.Layer;
    Set the Variable Profile Active for Selected Locked Section
        var locked_section = mapView?.GetSelectedLockedSections()?.FirstOrDefault();
          var variable = locked_section.Layer.GetVariableProfile(locked_section.VariableName);
          locked_section.Layer.SetSelectedVariableProfile(variable);
    Lock a Section/Create a Locked Section
        if (voxelLayer.Visualization != VoxelVisualization.Surface)
          voxelLayer.SetVisualization(VoxelVisualization.Surface);
        voxelLayer.SetSectionContainerExpanded(true);
        voxelLayer.SetLockedSectionContainerExpanded(true);
        voxelLayer.SetLockedSectionContainerVisibility(true);
        //Use the SelectedVariableProfile to get the sections
        //via its associated volume
        var volume = voxelLayer.SelectedVariableProfile.Volume;
        //get the selected section
        var section = mapView.GetSelectedSections().FirstOrDefault();
        if (section == null)
          section = volume.GetSections().FirstOrDefault();
          return;
        //Lock the section (Creates a locked section, deletes
        //the section)
        //if (voxelLayer.CanLockSection(section))
        //	voxelLayer.LockSection(section);
        if (volume.CanLockSection(section))
          volume.LockSection(section);
    Unlock a Locked Section
        voxelLayer.SetSectionContainerVisibility(true);
        //get the selected locked section
        var locked_section = mapView.GetSelectedLockedSections().FirstOrDefault();
        if (locked_section == null)
          locked_section = voxelLayer.GetLockedSections().FirstOrDefault();
          return;
        //Unlock the locked section (Deletes the locked section, creates
        //a section)
        if (voxelLayer.CanUnlockSection(locked_section))
          voxelLayer.UnlockSection(locked_section);
    Requirements
