| | Name | Description |
 | AddExploratoryAnalysisAsync |
An asynchronous function to add an ExploratoryAnalysisBase subclass instance to the MapView. Calling
this method activates the Exploratory Analysis object and presents it on the view.
 | AddOverlayControl |
Add a control over the view.
 | CancelDrawing |
Stop the current drawing of the MapView.
 | CanSetMapTOCContent |
Gets whether the specified map TOC content type can be set on the
active TOC.
 | CanSetStereoCursorMode |
Checks whether the stereo model's cursor mode can be toggled between fixed and
floating states. This method must be called on the MCT. Use QueuedTask.Run.
 | CanSetViewingMode | Gets a value indicating if the view can be changed to the provided ArcGIS.Core.CIM.MapViewingMode. |
 | CanShowElevationProfileGraph |
Checks to see if an elevation profile can be displayed.
 | CaptureThumbnail |
Capture a bitmap of the MapView content.
 | ClearTOCSelection |
Clears the selection from the TOC.
 | ClientToMap |
Converts a point in client coordinates relative to the top-left corner of the view to a point in the coordinates of the map or scene. This method must be called on the MCT. Use QueuedTask.Run.
 | ClientToScreen |
Converts a screen point to a point in client coordinates relative to the top-left corner of the view.
 | CloseActivePopup |
Closes the active popup window. You must be on the UI thread to call this function
 | ClosePopups | Overloaded. |
 | Export | Overloaded. |
 | ExportScene3DObjects |
Exports the scene contents to an exchange format.Supported export formats: glTF and stereolithography(STL).
 | FlashFeature | Overloaded. |
 | GetCameraEffect |
Returns the CIMCameraEffect object for the active 3D View.
 | GetElevationProfileGraph |
Gets the elevation profile graph for the mapView. This may return null if no elevation profile graph is visible.
 | GetExploratoryAnalysisCollection |
Get a list of the Exploratory Analysis objects that exist
for this MapView. You can check each object's type to identify
which subclass it is.
 | GetFeatures |
Return features that intersect a geometry. This method must be called on the MCT. Use QueuedTask.Run.
 | GetFeaturesEx |
 | GetOverlayControls |
Get all the current overlay controls.
 | GetPostprocessingEffects |
Returns an array of active CIMPostprocessingEffect objects for the active 3D View.
 | GetSelectedDataSourceMember |
Returns the selected DataSourceMember.
 | GetSelectedElevationSourceLayers |
Returns the collection of elevation source layers selected in the TOC.
 | GetSelectedElevationSurfaceLayers |
Returns the collection of elevation surface layers selected in the TOC.
 | GetSelectedIsosurfaces |
Returns the collection of voxel isosurfaces selected in the TOC.
 | GetSelectedLayers |
Returns the collection of layers selected in the TOC.
 | GetSelectedLegendClasses |
Returns the collection of legend classes selected in the TOC.
 | GetSelectedLockedSections |
Returns the collection of voxel locked sections selected in the TOC.
 | GetSelectedSections |
Returns the collection of voxel sections selected in the TOC.
 | GetSelectedSlices |
Returns the collection of voxel slices selected in the TOC.
 | GetSelectedStandaloneTables |
Returns the collection of tables selected in the TOC.
 | GetStereoCursorPosition |
Gets the current stereo cursor position as a map point.
 | GetViewSize |
Returns the current size of the view.
 | GetVisualEffect |
Returns the CIMVisualEffect object for the active 3D View.
 | HasNextCamera |
Indicates whether the map view has a next camera position.
 | HasPreviousCamera |
Indicates whether the map view has a previous camera position.
 | Invalidate | Overloaded. |
 | LookAt |
Center the view at a given point. This method must be called on the MCT. Use QueuedTask.Run.
 | LookAtAsync |
 | MapToClient |
Converts a point in the coordinates of the map or scene to a point in client coordinates relative to the top-left corner of the view. This method must be called on the MCT. Use QueuedTask.Run.
 | MapToScreen |
Converts a point in the coordinates of the map or scene to a point in screen coordinates. This method must be called on the MCT. Use QueuedTask.Run.
 | NextCamera |
Go to the next camera position. This method must be called on the MCT. Use QueuedTask.Run.
 | NextCameraAsync |
 | PanTo | Overloaded. |
 | PanToAsync | Overloaded. |
 | PanToSelected |
Pan the view to the extent of the selected features in the map or scene. This method must be called on the MCT. Use QueuedTask.Run.
 | PanToSelectedAsync |
 | PreviousCamera |
Go to the previous camera position. This method must be called on the MCT. Use QueuedTask.Run.
 | PreviousCameraAsync |
 | Print | Overloaded. |
 | Redraw |
Force a redraw of the map view. This method must be called on the MCT. Use QueuedTask.Run.
 | RedrawAsync |
 | RemoveExploratoryAnalysisAsync |
Removes the provided ExploratoryAnalysisBase instance from the MapView. It
will no longer be tracked or drawn in the view. The parameter provided should be
destroyed after it has been removed to avoid errors or confusion.
 | RemoveOverlayControl |
Remove a control from over the view.
 | ScreenToClient |
Converts a point in client coordinates relative to the top-left corner of the view to a screen point.
 | ScreenToMap |
Converts a point in screen coordinates to a point in the coordinates of the map or scene. This method must be called on the MCT. Use QueuedTask.Run.
 | SelectDataSourceMember |
Selects the DataSourceMember in the TOC.
 | SelectElements |
Select elements that visually intersect a geometry.
 | SelectElevationSourceLayers |
Selects elevation source layers in the TOC.
 | SelectElevationSurfaceLayers |
Selects elevation surface layers in the TOC.
 | SelectFeatures |
Select features that intersect a geometry. This method must be called on the MCT. Use QueuedTask.Run.
 | SelectFeaturesEx |
 | SelectLayers |
Selects layers in the TOC.
 | SelectLegendClasses |
Selects legend classes in the TOC.
 | SelectStandaloneTables |
Selects standalone tables in the TOC.
 | SelectVoxelIsosurface |
Selects the voxel isosurface in the TOC.
 | SelectVoxelLockedSection |
Selects the voxel locked section in the TOC.
 | SelectVoxelSection |
Selects the voxel section in the TOC.
 | SelectVoxelSlice |
Selects the voxel slice in the TOC.
 | SetActiveRangeName |
Sets the active range name for the map view.
 | SetCameraEffect |
Sets the Camera Effect for the active 3D View. Only works on 3D Views.
 | SetCursorPosition | Overloaded. |
 | SetFieldOfView |
Sets the field of view angle of the scene view.
 | SetMapTOCContentAsync |
Sets the map TOC content type on the active TOC. This method must be called
on the UI thread.
 | SetPostprocessingEffects |
Set the Postprocessing Effects for the active 3D View. Only works on 3D Views.
Can set multiple effects simultaneously by adding them to the array being passed in.
 | SetSceneDrawingMode |
Sets the perspective of the scene view.
Sets the stereo model's cursor to either fixed or floating states.
 | SetViewingMode |
Set the perspective of the map view. This method must be called on the MCT. Use QueuedTask.Run.
 | SetViewingModeAsync |
Set the perspective of the map view..
 | SetVisualEffect |
Sets the Visual Effect for the active 3D View. Only works on 3D Views.
 | ShowCustomPopup | Overloaded. |
 | ShowElevationProfileGraph | Overloaded. |
 | ShowPopup | Overloaded. |
 | ZoomInFixed |
Zoom the Camera in by a fixed amount. This method must be called on the MCT. Use QueuedTask.Run.
 | ZoomInFixedAsync |
 | ZoomOutFixed |
Zoom the Camera out by a fixed amount. This method must be called on the MCT. Use QueuedTask.Run.
 | ZoomOutFixedAsync |
 | ZoomTo | Overloaded. |
 | ZoomToAsync | Overloaded. |
 | ZoomToFullExtent |
Zoom the view to the full extent of the map or scene. This method must be called on the MCT. Use QueuedTask.Run.
 | ZoomToFullExtentAsync |
 | ZoomToSelected |
Zoom the view to the extent of the selected features in the map or scene. This method must be called on the MCT. Use QueuedTask.Run.
 | ZoomToSelectedAsync |
