Public Function ZoomToSelected( _ Optional ByVal duration As Nullable(Of TimeSpan), _ Optional ByVal maintainViewDirection As Boolean _ ) As Boolean
public bool ZoomToSelected( Nullable<TimeSpan> duration, bool maintainViewDirection )
Parameters
- duration
- The amount of time to navigate the view to the new camera position. If null it uses the default navigation duration.
- maintainViewDirection
- Indicates if the Pitch and Heading should remain the same after the navigation is completed. If false the Heading will be set to 15.0 and the Pitch will be set to -60.0. This parameter only effects 3D views.
Return Value
True if the navigation is completed, false if it was interrupted by another view navigation.
