ArcGIS.Desktop.Mapping Namespace / MapView Class / SetStereoCursorMode Method
True or false depending on whether the cursor mode to set is fixed or floating respectively.
    Sets the stereo model's cursor to either fixed or floating states. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetStereoCursorMode( _
       ByVal cursorFixed As Boolean _
    public void SetStereoCursorMode(
       bool cursorFixed
    Parameters
    cursorFixed
    Exceptions
    ExceptionDescription
    The cursor fixed mode can only be set on Stereo views.
    Remarks
    Use CanSetStereoCursorMode to determine if a cursor mode can be set. Set cursorFixed to false to set the cursor mode to floating and to true to set it to fixed. If the current cursor mode is already the same as what is being requested (ie fixed or floating), no action is taken. If the DefaultViewingMode is not ArcGIS.Core.CIM.MapViewingMode.MapStereo or the mapview is not ready, a System.InvalidOperationException will be thrown. Use IsStereoCursorFixed to determine the current stereo cursor mode.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
