ArcGIS.Desktop.Mapping Namespace / MapView Class / CanSetStereoCursorMode Method
    Checks whether the stereo model's cursor mode can be toggled between fixed and floating states. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public bool CanSetStereoCursorMode()
    Public Function CanSetStereoCursorMode() As Boolean
    Return Value
    True if SetStereoCursorMode can be called.
    Exceptions
    ExceptionDescription
    Remarks
    Use CanSetStereoCursorMode in-conjunction with SetStereoCursorMode. False is returned when the DefaultViewingMode is not ArcGIS.Core.CIM.MapViewingMode.MapStereo or the mapview is not ready. Calling SetStereoCursorMode when CanSetStereoCursorMode returns false will result in an System.InvalidOperationException. Use IsStereoCursorFixed to determine the current stereo cursor mode.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
