ArcGIS.Desktop.Mapping Namespace / MapView Class / GetFeaturesEx Method
The geometry used to identify features that intersect it.
Indicates whether only features that visibly intersect the geometry should be returned.
This parameter only applies to 2D. Indicates whether only features that are completely within the geometry should be returned.
    Return features that intersect a geometry. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetFeaturesEx( _
       ByVal geometry As Geometry, _
       Optional ByVal visualIntersect As Boolean, _
       Optional ByVal whollyWithin As Boolean _
    ) As SelectionSet
    Parameters
    geometry
    visualIntersect
    whollyWithin
    Return Value
    The collection of layers and object ids that intersect the geometry.
    Exceptions
    ExceptionDescription
    3D views only support selecting features interactively using geometry in screen coordinates relative to the top-left corner of the view
    Requirements
