Parameters
- mapView
Return Value
A boolean indicating if non spatial data are displayed.
| Exception | Description |
| System.ArgumentNullException | Map cannot be null. |
| System.ArgumentException | Map is not a link chart. |
await QueuedTask.Run(() =>
// display non spatial data
MapView.Active.SetShowNonSpatialData(true);
// select the current set of non spatial data
var selNonSpatial = MapView.Active.SelectNonSpatialData();
// perform some action
// select the current set of spatial data
var selSpatial = MapView.Active.SelectSpatialData();
// perform some other action
